Re: Speedmaster heads?
[Re: Mr.Yuck]
#2201834
11/24/16 02:43 PM
11/24/16 02:43 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
anybody heard of these? heads Ya and I'm sure you did too. Speedmaster used to be Procomp and we all know procomp in JUNK. Take a look at ProMaxx on Summit or Jegs. I just checked out a set of their small block heads this Summer and they were VERY nice. And had higher flow numbers than Edelbrock heads on my bench.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Mr.Yuck]
#2202070
11/24/16 10:28 PM
11/24/16 10:28 PM
Posts: 14,531 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That particular head in the link is the Procomp copy of the bb victor head. Same thing that member RAMM used on an Enginemasters build a few years ago.
BradH sent me one to mess around with...... Seemed okay to me.
I'm always leary of the supplied parts in offshore heads, so I'd probably buy them bare and use parts I felt more comfortable with.
[Re: fast68plymouth]
#2202292
11/25/16 01:07 PM
11/25/16 01:07 PM
BradH
Yep, both Jesse (RAMM) and Randy Malik have used the Procomp / Speedmaster Victor clones in EMC builds a few years ago.
Out of the box, they're... ummm... "less than impressive." And even w/ good prep work, they are things you can't "fix" because of the way they're cast & machined at the source. Example: They have ugly steps below the exhaust seat rings which would require welding & replacing the seat inserts to correct... NOT cost effective.
Would I run a set? Depends... I know what they're capable of w/ porting (and have posted those results on here in the past), but would probably want to limit them to flat-tappet spring loads (paranoid, maybe?).
No way I'd trust any of their hardware, either, like Dwayne said. If you want to buy a bare set, I can provide you w/ a set of dyno-time only Edelbrock Victor valves for a good price. Dwayne's already seen my "Crash Test Dummy" head in person, so he'd be a good person to send the parts to for machine work, porting, etc.
IMO, they're only a good deal if you can keep the costs down. Oh, and they're going to require .600"-ish offset intake rockers, too, just like the Victors.
[Re: BradH]
#2202299
11/25/16 01:21 PM
11/25/16 01:21 PM
Posts: 1,561 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Jeff,
Don't buy questionable stuff. Sounds like you would be gutting them and buying valves, springs, retainers and doing a valve job= $$$$$$.
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: 440PURSUIT]
#2202302
11/25/16 01:26 PM
11/25/16 01:26 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Jeff,
Don't buy questionable stuff. Sounds like you would be gutting them and buying valves, springs, retainers and doing a valve job= $$$$$$. And then you still have questionable valve guides and seats. Run while you can as there are to many better options out there.
[Re: Mr.Yuck]
#2202340
11/25/16 02:15 PM
11/25/16 02:15 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yup, figured as much. I saw the Jeg's ProMaxx looked like decent. Here's the post I did on the ProMaxx small block heads. Check out the flow difference between these and the Edelbrock heads and check out the difference in the pictures of both. https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2140321/1.html
[Re: pittsburghracer]
#2202482
11/25/16 06:12 PM
11/25/16 06:12 PM
440PURSUIT
DC, MD Suburbs
Jeff,. Edelbrock has a $150 rebate on a pair of heads going til end of year.
