Dakota heater #2200741
11/22/16 08:20 PM
11/22/16 08:20 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
On a 96 Dakota.....what controls the speed of the blower motor , other than the switch ?
mine is only working on High .....
Re: Dakota heater [Re: 493_DART] #2200748
11/22/16 08:33 PM
11/22/16 08:33 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Bad switch or bad resistor. Most likely it is the resistor
Re: Dakota heater [Re: 493_DART] #2200821
11/22/16 10:23 PM
11/22/16 10:23 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
twocents
Resistor located in engine bay.
Re: Dakota heater [Re: 493_DART] #2200867
11/22/16 11:30 PM
11/22/16 11:30 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
thanks guys---where is it? firewall?
Re: Dakota heater [Re: 493_DART] #2200882
11/22/16 11:48 PM
11/22/16 11:48 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
The blower motor resistor is located at the passenger side upper firewall. They are prone to connection issues and melting the plug that goes to them. The resistor itself is usually reusable after the connector terminals have been cleaned.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Dakota heater [Re: 71yelladustr] #2200994
11/23/16 02:10 AM
11/23/16 02:10 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Couldn't have said it better myself. I have a '96 Dak and have to pull the connector every few months and clean it.
Re: Dakota heater [Re: 493_DART] #2201025
11/23/16 03:19 AM
11/23/16 03:19 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
sweet----------thanks boys !!!
Re: Dakota heater [Re: 493_DART] #2201029
11/23/16 03:24 AM
11/23/16 03:24 AM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Here's mine:
Re: Dakota heater [Re: 493_DART] #2203594
11/27/16 11:15 PM
11/27/16 11:15 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
yep.....have a melted plug.....
ill see if i can find a nice one at the junkyard
Re: Dakota heater [Re: 493_DART] #2204560
11/29/16 05:11 PM
11/29/16 05:11 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
As long as your in there pop your resistor out and check for corrosion. Mine was so bad eventually the fan stopped working altogether. I clipped the wire and stuck in the available slot on the 4-position common bus. Check the pic; you can see where I clipped it off and moved it over.
Re: Dakota heater [Re: 493_DART] #2207205
12/03/16 10:05 PM
12/03/16 10:05 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
found a bunch at the yard......picked a clean plug and resistor and installed..........fan works perfect
cost = $2.50
