Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201598
11/24/16 01:10 AM
11/24/16 01:10 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The pictured puller Is for a pitman arm. Look closely at the center bolt, it has a point on it to center it on the steering shaft. That point will walk off the side of the flat end of a tie rod. You will have to grind off the point. Check the width of the jaws first. They are too wide for Mopar tie rods.
Re: Easier way to remove center steering link? [Re: NANKET] #2201604
11/24/16 01:24 AM
11/24/16 01:24 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
use the hammer ..... gotta have a strong arm for some of them !!
Re: Easier way to remove center steering link? [Re: 70satelliteguy] #2201732
11/24/16 12:39 PM
11/24/16 12:39 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I wonder how the OP faired?
Don't be the exception.
Re: Easier way to remove center steering link? [Re: NANKET] #2201899
11/24/16 04:16 PM
11/24/16 04:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
They make a similar tool for tie rod ends but I've had mixed results with them. If the rod end is really tight they will flex too much and even the blunt end tends to walk off to the side.
Re: Easier way to remove center steering link? [Re: Supercuda] #2202212
11/25/16 03:36 AM
11/25/16 03:36 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I'm sure its off by now, with the given advice. up
Re: Easier way to remove center steering link? [Re: feets] #2202250
11/25/16 11:13 AM
11/25/16 11:13 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Originally Posted By feets
Throw the pickle fork in the junk metal pile.
Get one of these pullers.
Turn the bolt until you think it won't take any more and whack the link as close as possible to the joint. It'll pop right off.
I see your puller and raise you this one. Hands down a much better design. Load up the puller in decent tension and if it doesn't let loose, a tap with a hammer will get it. I've used this one hundreds of times.
http://www.harborfreight.com/3-4-quarter-inch-forged-ball-joint-separator-99849.html
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Easier way to remove center steering link? [Re: NANKET] #2202275
11/25/16 12:21 PM
11/25/16 12:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Someone forgot to tell my center links about those problems. It popped 'em right off.
When I'm using one of these tools I generally spin the nut off, flip it over, and spin it most of the way back on. That helps keep the pieces contained when they pop.
Most joints will have a center point cut into them as a byproduct of manufacturing. The tool will line up nicely on them.
I have both the tie rod end pulled and the pitman arm puller. They work well for drag links and the occasional ball joint too.
- Stu Harmon
Re: Easier way to remove center steering link? [Re: feets] #2202296
11/25/16 01:15 PM
11/25/16 01:15 PM
Penna
70satelliteguy Offline OP
Penna
Sorry for the late reply,Thanksgiving and all. I got it off finally by beating with a hammer and wedging a large screwdriver between steering link and pit-man arm.The pickle fork did not do the trick. I will however go to my local Harbor Freight and get some kind of puller as this held me up for a day.
Thanks Mike
