R4 block for a p5 head??? #2199167
11/19/16 11:15 PM
11/19/16 11:15 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I'm curious are there any R4 blocks available. that can be used with a P5 cylinder head.... also looking at rocker gear possibilities. And if anybody knows the bore space of one of these engines.it would be helpful... thank you ahead of time..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199173
11/19/16 11:32 PM
11/19/16 11:32 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: R4 block for a p5 head??? [Re: J_BODY] #2199190
11/20/16 12:08 AM
11/20/16 12:08 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
I think that is a wedge head block. p5007151ac listed as a 45/59 angle lifter. real short deck 8.58"
Because you have had such good luck with your Ritter block maybe you would like one of his x2 blocks stirthepot
https://www.amazon.com/Mopar-P5007151AC-Race-Block/dp/B007NPUOCE
"Just a Bracket car dressed up like a streetcar"
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199206
11/20/16 12:49 AM
11/20/16 12:49 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
standard sb bore space. Those are hemi head blocks. Lifter bore spacing and angles are wrong, head bolt pattern is wrong. I looked into this also.
Re: R4 block for a p5 head??? [Re: TRENDZ] #2199219
11/20/16 01:14 AM
11/20/16 01:14 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
You could try contacting Bob Book, as he builds a few of these engines now. Don't get him started about the blocks however, he's not a fan. For the Aussie Pro Stock engines he fills them with grout and sleeves all 8 bores to get the bores stable.
Alan Jones
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199238
11/20/16 01:53 AM
11/20/16 01:53 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
P5007151AC..... there are 9 of these blocks in Warren MI depot.
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199239
11/20/16 01:55 AM
11/20/16 01:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and there's still 8 P9 heads there too.
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199358
11/20/16 01:58 PM
11/20/16 01:58 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
DREAM COMBO!!
Re: R4 block for a p5 head??? [Re: SpareParts] #2199455
11/20/16 05:29 PM
11/20/16 05:29 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Originally Posted By SpareParts
DREAM COMBO!!
Yea it's sexy but just about impossible to make go down track with heavy car.
2600-2700 ready to go down track. About as heavy as you would want to be.
All out P7 much better choice. Not as sexy but p7 on kill can make 1100-1140HP
HAS been done with SB2 and P7 just a better SB2 just takes buckets of money.
P5 on kill 1200ish and not fun to make work in a car.
440CI W8 on kill can make 1020-1040 and they make lots of torque.
Much easier to get car to work with w8 deal
3000lbs 440 w8 should go 162-164 Mph.
How fast you want to go and at what cost?
Re: R4 block for a p5 head??? [Re: WHITEDART] #2199589
11/20/16 09:46 PM
11/20/16 09:46 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I just want to go!
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: R4 block for a p5 head??? [Re: 1967dartgt] #2199602
11/20/16 10:12 PM
11/20/16 10:12 PM
bean town ....Ca
W
W
bean town ....Ca
Originally Posted By 1967dartgt
I just want to go!
you will soon.. you're in good company
Re: R4 block for a p5 head??? [Re: WHITEDART] #2200030
11/21/16 04:45 PM
11/21/16 04:45 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The only heads to get are the Vizner stuff. All the Mopar cast heads out there, and that is only a few usually have issues with the castings. They made very very few of them to begin with. Bad A$$ stuff for sure but purpose built pieces too. The deck height is very short and bore space is stock as that was required by Aussie and Truck rules. RWR did a number of them over the years for a couple Aussie teams and Comp guys.
Re: R4 block for a p5 head??? [Re: Al_Alguire] #2200175
11/21/16 08:41 PM
11/21/16 08:41 PM
LA360 Offline
LA360  Offline
All the fastest Aussie Pro Stock stuff are running the Slawko Billet heads, Visner was the first to do the billet P5 head as far as I understand. You look at any of these engines and you'll see that the decks are that low, that the almost break through the bell housing flange at the rear of the block. An all out 399 ci P5 engine from Bob Book won't leave you much change from $100K
As Al stated, the cast heads have their limitations, most would crack in the intake bowl, not sure if the P9 head has the same issues.
Alan Jones
Re: R4 block for a p5 head??? [Re: WHITEDART] #2200414
11/22/16 04:27 AM
11/22/16 04:27 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pretty sure the Slawko stuff are the Vizner pieces. When Waters was working with Vizner there were some things he wanted done that VIzner did not do. I think Slawko picked up from there.
