Re: Bilstein adjustable shocks 2015 ram.
[Re: Dono]
#2195367
11/12/16 09:33 PM
11/12/16 09:33 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Put 5100 series on my '14 and they worked out nicely.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: Dono]
#2196956
11/15/16 09:27 PM
11/15/16 09:27 PM
Posts: 129 London Ontario Canada Eh
Dono
Looks good. My math is telling me I will have about 1" rake still if set in at the 2.1" setting.
Do you hook any trailer on the back? Will I be looking for an air bag kit to use my trailer?
This 15 is 1.5" taller than the 06 I had but rides so much better......
Cheers Don.
P.S. here is a picture of the 2015. Shes a bit dirty but you can see the before how low the front is to the back.
[Re: Dono]
#2197505
11/16/16 07:36 PM
11/16/16 07:36 PM
dfsmopars
Kentucky
Cheers Don.
P.S. here is a picture of the 2015. Shes a bit dirty but you can see the before how low the front is to the back. Yes I set mine at 2.1". Your truck looks to be a bit lower in the front than mine from the factory. I do pull a trailer but I use a load leveling hitch so no issues. I was prepared to install new springs in the back from SD TruckSprings if necessary.
