1970 440 detail
#2197294
11/16/16 11:31 AM
11/16/16 11:31 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
hey gang.. Looking for some close up detailed pictures of survivor, or correctly restored, 440's, in particular 1970. One question I have is the 4 water pump housing attach bolts. Do all 4 have a washer or only the one behind the heater hose nipple on the passenger side. I need to get a proper thermostat housing, 2780970 ( anyone have good one? ). I believe the heater hose nipples were installed and the tips where the hose goes masked off prior to painting? I believe I should also have the insulation packed under the intake manifold?
I still need to get the water pump installed obviously before I paint it.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 1970 440 detail
[Re: B5Cuda440-6]
#2197880
11/17/16 10:42 AM
11/17/16 10:42 AM
Posts: 2,644 Nashville, TN
MOPARMIKE69
Nashville, TN
I have a detailed section about these washers in Keven Shaw and my book by car tech. How to restore 66 - 70 Mopar B-bodies.
I disassembled an original untouched 383 from an original low mileage car. Not saying all of the engines were exactly the same but I have found that all the water pump bolts have washers except for the one behind the heater hose nipple.
Found the same thing on the 440 I built in a 71 GTX and also in a 1970 Hemi I am currently building.
In a washer pump housing bolt kit I just bought from Frank Badalson it included 5 bolts and 4 washers.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: 1970 440 detail
[Re: MOPARMIKE69]
#2197925
11/17/16 12:10 PM
11/17/16 12:10 PM
hemi68charger
Houston, Tx
In a washer pump housing bolt kit I just bought from Frank Badalson it included 5 bolts and 4 washers. thanks... Think I'll get one..... Know a lot, relatively speaking.. Never too late to learn more.......
Re: 1970 440 detail
[Re: hemi68charger]
#2198043
11/17/16 03:43 PM
11/17/16 03:43 PM
Posts: 3,560 Lansing, MI
70gtx440dana
Lansing, MI
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 1970 440 detail
[Re: FJ5_Fish]
#2217227
12/19/16 07:36 PM
12/19/16 07:36 PM
Posts: 6,246 JERSEY
RJS
JERSEY
On all the '70 440's I have or have had there is only one bolt that gets a washer.....the one behind the water pump nipple. The only other bolt that has a washer is if the engine has power steering. On the lower power steering bracket that bolt is painted when the engine gets painted, gets removed and is then used for the power steering bracket. Attached is a pic from my survivor Bird.
Having said that - I'm sure there have been some variances on years, engine sizes etc.
Where is the Orange paint supporting that statement?? Never saw that in my life but I haven't taken more than a handful of Survivor types apart. Ron
