Ok - I saw this thread a couple of weeks ago but didn't have a chance to reply. This is a bit long but there's a lot to this topic so read along to see where I'm at WRT updated technology headlamps for our old musclecars.
I swapped out the 7" sealed beam lights on my 1972 Cuda with a set of Hella reflector housings with the Hella H4 bulbs back in the early 90's. That was a decent improvement in light output. I cleaned all my electrical connectors before I did the swap. But I did have a slight voltage drop (0.3V) using the stock wiring so I then added a relay connected to the alternator lead on the starter relay stud. The 0.3 of a volt loss was noticeable in the bulb brightness. That was about the best I could do for back then.
In 2004, I purchased an Acura TSX with HID low beams ... WOW - that was light years ahead (pun intended) of any DOT approved lighting system I had ever had on any of my cars/trucks. The HID system on that Acura lit things up an extra 500 ft down the road from a halogen. It had a sharp horizontal cutoff line and anything reflective down the road jumps out at you. That HID Technology was very impressive. As I get older (50's), my night vision isn't as good. HID makes up quite a bit for older eyes. You can see the deer from much further away (front and to the sides) and slow down a bit to avoid any collisions.
I really wanted to convert the Cuda to a Bi-Xenon setup but it looked to be pretty expensive (>$500). And after ~8 years, the HID system on the Acura started to need expensive maintenance. The HID systems are complicated with ballast, igniter, salt chamber bulb and projector housing. Lots of things to go wrong and did I mention that the ballast hits the bulb with an initial jolt of 25KV AC to get the salt to turn into plasma? You have to be very careful (shock hazard) around the bulb ignitor when you turn the headlights on. So I never did make the leap to HIDs on the Cuda.
I've watched the LED headlight technology evolve to the point where I think it now can give the HID Systems a run for their money. JW Speaker 8700 Evolution 2 is the headlight that I was looking at. That's also a $500 upgrade. The 2000-2016 Jeep guys like to retrofit to LED or HID for better off-road lighting. I've been watching the 7" LED conversion market for some time. Back when I was looking at HIDs, the guys at
www.theretrofitsource.com were putting together some good kits out of OEM Parts they were sourcing from new cars that wound up in auto salvage yards. And they were also working with
www.morimotohid.com to create new HID retrofit kits. I was out on the retrofitsource website and saw that they were blowing out their inventory of new Morimoto Sealed7 Bi-LED Headlight (7" Round) for $85 a piece ($170 for a pair plus free shipping). They said that Morimoto was coming out with a new version of the 7" LED so they wanted to clear their inventory of the old model. So I purchased a set of these LED lights last week (Nov 16, 2016).
When I go out to the Morimoto website, I don't see any mention of a new version of the 7" LEDs so I'm not sure that the Retrofitsource was giving me the straight scoop on why they were blowing these headlamps out. I have the lamps at home in my garage and will try to swap them in over the Thanksgiving break. They look like high-quality units. The have a pretty big heatsink on the back so I'm not sure they will swap right into the headlight buckets on the Cuda. I'm prepared to do a little customizing to get these on my car.
I was going to wait to get them installed and report back my thoughts on performance but then I decided to just write this up now and add to it later. I did go back out to the webpage on the Retrofitsource so I could provide a link here in this write-up but the page has been removed so I must have gotten close to the last pair that they had in stock. Hopefully, these LEDs will be a significant improvement and I'll be happy until the new Lazer-Xenon Gen III IMax Projector HIDs come out in the 2025 Hellcats
There you have it ...
-Joe
PS: I think that Monza from Street Outlaws runs this type of light on his Camaro. I looked at the pictures in his write-up the latest Hot Rod Magazine and they look the same. But he can probably afford the JW Speaker LEDs. If they're good enough for Monza, they're good enough for me. Maybe they'll make my car faster ....
