340 Six Pack, why is it slow revving off the line?
#2195765
11/13/16 04:14 PM
11/13/16 04:14 PM
Posts: 765 Vancouver, WA
Cuda Cody
Vancouver, WA
Stock 340 TA build with Mr. Six Pack cam (114 lobe separation). Car starts, idles and runs great, but is slow to rev under load. In neutral it revs fast and once up to speed and driving it pulls hard, but from a stop the engine is slow revving / lacking power. Not really bogging as not running right, but bogging as if I'm pulling a trailer. No smell of excess fuel, but just doesn't have much power until about 2,500 rmp and then it takes off fast.
Had a friend that works at a auto shop sniff test (with a Snapon machine) the car under load and it was running super lean, but at idle was perfect. The center carb had a 61 main jet in it when I got it back from the guy that restore them (and that the jet it was sniff tested with). I've gone up to 64 then 68 and now I'm all the way up to 80. It would seem like that is way to much for a center main jet on a 340, but every time I add more main jet it runs better and gets faster on the top end. But it still revs slow on the bottom end and takes off like it's waiting to wind up. I think the big main jet on the center is trying to mask the real problem that might be the outboard carbs not getting enough fuel to the engine when launching from a stop. Once the RMPs get going its like a raped ape chirping the tires as it grabs gears.
In the outboard carbs vacuums, I've tried the lightest springs (white), both yellows (short and long), purple and the plain spring. The long yellow seemed to work best. But the way it feels to me is the outboard carbs are not putting enough fuel in whenever the gas is mashed regardless of the spring / timing they open. Really feels like a 2 barrel 318 stock engine for a few seconds until it winds up.
On the accelerator pump I started with the white cam, then orange and green. It like white and orange best. The intake vacuum at idle is about 15 to 16 in neutral and in drive (at idle) is 13 to 14. Was using a 6.5 power valve, but went up to a 7.5 and it liked the extra fuel a little sooner. On the engine run stand if I opened all the carbs at the same time (manually) it revved SUPER fast, but that wasn't under load so doesn't help me now.
The car is running the Rev-N-Nator electronic ignition, stock intake and exhaust manifold with stock T/A heads. At 2,500 it's at 35 degrees of timing and at idle it's 15. Just for fun I put a different brand new 340 center carb (same jet set up with the same cam as I was running) and it the engine runs the same as the first original carb. So doesn't seem to me it's the center carb that causing this.
I'm out of ideas guys.
Thanks in advance for any thoughts or comments.
1970 Challenger T/A 4-Speed 1970 Challenger T/A 4-Speed 1970 Challenger T/A Auto 1970 Challenger R/T Auto 1970 Challenger Auto 1970 Challenger RT 440+6 4-Speed 1970 Challenger RT 440+6 4-Speed 1970 Hemi Challenger 4-Speed 1970 Hemi Cuda 4-Speed 1971 Cuda Auto 1971 Cuda 4-Speed LOOKING to BUY 1970 & 1971 E Body J, V and R Code project cars
Re: 340 Six Pack, why is it slow revving off the line?
[Re: Cuda Cody]
#2195773
11/13/16 04:19 PM
11/13/16 04:19 PM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
What is your transmission, and gear ratio? I have a friend who built a 340 that isn't much better than his old 318 off the line, but pulls hard once it's going. He is running 3.23
[Re: Cuda Cody]
#2195777
11/13/16 04:26 PM
11/13/16 04:26 PM
Posts: 43,282 Bend,OR USA
Cab_Burge
How are the float levels and fuel supply? Have you changed or fixed the kill bleeds on the outboards yet? I and a bunch of other six pack racers use a screw and nut on the return slot to help open the outboards quicker
[Re: killermopar]
#2195794
11/13/16 04:56 PM
11/13/16 04:56 PM
Cuda Cody
Vancouver, WA
It's a stock 727 floor shift Auto with stock a 8 3/4 (3.55) sure grip rear. The trans was built by a good friend that has passed away. He was the Dodge factory Auto transmission guy for Beaverton Dodge in the 70's and built transmissions on the side after he retired. Can not say for sure what the stall converter is, but it feels like it's hooking up solid.
As for the fuel pressure it's great, but not sure about the float levels. That something I have not checked yet. Thanks for the reminder and I'll take a look at them to make sure they are set correctly. Not sure what the Kill Bleeds are so I can assure you I have no clue where they are are how they are set. It seems to me that if I can get the outboards to put more fuel in quicker it should solve the problem.
I'll have to find my machine shop spec sheet to look up the degree of the cam. Something I haven't thought of yet. Good suggestion.
The initial timing is 15. At 2,500 it's 35. I do not have the vacuum advance hooked up either. I've always set my timing with them disconnected. Maybe that's part of my problem?
[Re: Cuda Cody]
#2195819
11/13/16 05:39 PM
11/13/16 05:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your base timing could be higher but you would need to recurve the advance so you dont go too high at total... but about 19* should be pretty good... cam timing would help it a lot(advancing it)... more than likely it would say about 108- 110 installed but if it wasnt it will be slow.. even 104 to 106 should really help low end.. but if you do that it moves the whole curve lower in the rpm and you loose top end rpm.. but if you dont ever get up in the high rpm you dont need it
[Re: Cuda Cody]
#2195837
11/13/16 06:27 PM
11/13/16 06:27 PM
Cuda Cody
Vancouver, WA
I thought vacuum leak first off too. No way a 340 should be happy with an 80 main jet is what I was thinking. Not sure on the timing chain brand, but I always use quality parts. I would need to look up the receipt to know for sure. Tires are stock reproduction Polyglas.
The compression is 9.1 to 1. The engine runs and idles fantastic. It's just that pesky lazy launch. I think it's going to be best to put it on a dyno and watch how the outboard carbs react under load. And that way I can get some good A/F reading under heavy load too. The next dry day we get I'll take it down and see what it does on the dyno.
Thanks for the help guys and I'll be sure to update what I find.
[Re: dvw]
#2195839
11/13/16 06:28 PM
11/13/16 06:28 PM
Cuda Cody
Vancouver, WA
Good idea. Contact Bob K. he knows these carbs as well as anyone. especially if you have his cam. Doug
[Re: polyspheric]
#2196133
11/14/16 12:47 PM
11/14/16 12:47 PM
Posts: 12,414 Taxes & Virus's R-US, NY
Dragula
It could be the convertor is a tad tight, but lets think about this for just a second...
With vacuum carbs, your motor needs to draw enough signal to open the vacuum pods and apply the needed fuel. This means, it has to go very lean to even draw the pods open.
If your not launching at or near your shift point, its going to be lean until the engine rpm rises enough to draw in the fuel which its not getting....We call it a bog. And that is what vacuum carbs do.
We have a 572 Hemi we dyno'd with a six pack, same issue...jet it all you want. Doesn't help. We had to raise the loading point of the dyno just to get past it. A standard 950 race carb, was over a tenth quicker just because of the bog.
Three center carbs is your best bet...
[Re: Monte_Smith]
#2196138
11/14/16 12:53 PM
11/14/16 12:53 PM
Cuda Cody
Vancouver, WA
That's something I've never considered. When you say to tight you mean a stall converter is to low, right? And it makes sense. I notice when I shift from Park to R or D it really grabs hard. It's what I would describe as a very noticeable "grab" in to gear even with your foot on the brake. It could be as simple as the converter is too tight
[Re: Cuda Cody]
#2196153
11/14/16 01:32 PM
11/14/16 01:32 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If you chassis dyno it, you should be able to get a pretty good idea of what the stall is...... Along with power, a/f ratio, and be able to see how the secondaries are operating.
