Driveshaft Help #219539
02/09/09 09:36 PM
02/09/09 09:36 PM
Atco NJ
Mr Bojangles Offline OP
Atco NJ
I need a drive shaft for my 1966 Belvedere 440/727. Is there a common junk yard swap or some car close in size that anyone has used. I think the length is about 52.25 inches. A friend suggested getting a truck drive shaft and having it cut down but to size. Any suggest?
1965 Belvedere II 440 4psd 4.10 Driver 1966 Belvedere II Race Car Project 1970 Duster Street Car Project 2003 Hemi Ram Quad Cab 4x4
Re: Driveshaft Help [Re: Mr Bojangles] #219540
02/10/09 01:05 AM
02/10/09 01:05 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
are you useing the 8-3/4 rear as the smaller rear uses a different length, having one cut to fit is way better if you cant find one coz they usually ballance and install ne u-joints.
Re: Driveshaft Help [Re: moparsquid] #219541
02/10/09 10:00 AM
02/10/09 10:00 AM
Atco NJ
Atco NJ
Sorry I forgot it is an 8 3/4...Has anyone tried an aluminum drive shaft? I was told later model gm pickups have them. I was wondering if that would be even better?
Re: Driveshaft Help [Re: Mr Bojangles] #219542
02/10/09 09:05 PM
02/10/09 09:05 PM
Atco NJ
Atco NJ
Looking for an answer. Anyone used an aluminum truck drive shaft? Going to the bone yard tomorrow.
Re: Driveshaft Help [Re: Mr Bojangles] #219543
02/10/09 09:30 PM
02/10/09 09:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just had one made for my 63. I ordered it thru Mancini and told them what front and rear yokes I had. Then I just gave them the center to center driveshaft lenth. My was mild steel for my 63. I have not used an aluminum one but I guess you could measure one and make sure it's long enough. Then see if the yokes are right and then of course have it cut and balanced to your lenth. I myself have not ever heard about a truck shaft with the right ends on it. Ron
Re: Driveshaft Help [Re: 383man] #219544
02/10/09 11:28 PM
02/10/09 11:28 PM
Atco NJ
Atco NJ
Hey Ron thanks. You always come thru for me
About how much did it run you if you remember?
Re: Driveshaft Help [Re: Mr Bojangles] #219545
02/13/09 01:48 AM
02/13/09 01:48 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I believe I paid right about $200. dollars with shipping. Sorry about not getting back to fast. Been real busy this week. Ron
Re: Driveshaft Help [Re: 383man] #219546
02/13/09 11:36 AM
02/13/09 11:36 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
I got my drive shaft from http://www.thrashdriveshaft.com/
and I'm very happy with it, I used 13 series joints with u-bolts. Mine was around $300.00 or so.
IMO it's best to have the car about done at race weight and ride height set or close as you can to done then measure for the driveshaft....
Re: Driveshaft Help [Re: Gary67] #219547
02/13/09 01:20 PM
02/13/09 01:20 PM
Atco NJ
Atco NJ
Hey Gary Thanks. Nice cars. Its nice to see another 66-67 fan here in Jersey.
Re: Driveshaft Help [Re: 383man] #219548
02/13/09 01:40 PM
02/13/09 01:40 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
2 wheel drive 1/2 ton pickups with a 727 will have the right yoke and joints (if you have the small joint) but will more than likely the wrong length.
