Page 1 of 3 1 2 3
Disc brakes on Duster 340's #2195100
11/12/16 11:29 AM
11/12/16 11:29 AM
Massachusetts
RAII4-speed Offline OP
Massachusetts
I am trying to find out if disc brakes were standard equipment on Duster 340's for the years 1970,1971,1972 And 1973.
I have come up with conflicting answers from the Internet.
Of coarse, original window stickers and Factory info would help.
Barry Washington --- Your thoughts and remarks are not welcome on my posts.
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195107
11/12/16 11:51 AM
11/12/16 11:51 AM
Texas
Three40 Offline
Three40  Offline
Texas
Hey RAII4_speed, The 1970 Duster 340 came standard with the 4 piston caliper Kelsey Hayes disc brakes as standard equipment.The power assist was an option. 71 and 72 drum brakes were standard and power assist was again an option as well as disc brakes were now an option. the 1973 Duster 340 came standard with disc brakes.This year (1973) it also became the 4.5 inch bolt pattern wheel instead of the 4.00 inch bolt pattern wheel like the 70,71 and 72 used.Hope this helps you out.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195108
11/12/16 12:03 PM
11/12/16 12:03 PM
Massachusetts
Massachusetts
Three40 .... That does help but still conflics with my findings.
Check out this original window sticker I found on E Bay, it says differently...
http://www.ebay.com/itm/1972-DUSTER-340-3-SPEED-GY8-V6X-BUILD-SHEET-BROADCAST-OEM-WITH-DOOR-STICKER
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195111
11/12/16 12:08 PM
11/12/16 12:08 PM
Massachusetts
Massachusetts
Also, My findings say that 1973 Duster 340's came standard with POWER disc brakes ...very confusing...
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195113
11/12/16 12:10 PM
11/12/16 12:10 PM
Massachusetts
Massachusetts
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195117
11/12/16 12:14 PM
11/12/16 12:14 PM
Massachusetts
Massachusetts
1972 window sticker .....
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195180
11/12/16 02:46 PM
11/12/16 02:46 PM
Let see, your asking about this on this forum on the internet, why work
Re: Disc brakes on Duster 340's [Re: Cab_Burge] #2195211
11/12/16 03:48 PM
11/12/16 03:48 PM
Texas
Three40 Offline
Three40  Offline
Texas
Hey RAII4-speed, You are correct on the 73s. I own a 73 Dart Sport 340 and it came standard with power disc brakes and is also listed in the literature for the 73 that power disc brakes were standard on the 340 car.The 72s have me perplexed as I owned a 72 Demon 340 and it was a manual drum brake car. I have also looked at other 72s that had manual drum brakes and were legit 340 cars.On ebay right now there is a HB1 Blue 72 Demon 340 a factory 340 3 speed stick car and it has manual drum brakes on it. Dont know if maybe it depends on when they were built? I also parted a 72 340 Duster that was rusted completely out and it to had manual drum brakes on it.
Re: Disc brakes on Duster 340's [Re: Three40] #2195226
11/12/16 04:04 PM
11/12/16 04:04 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I had 2 '72 340 Dusters, both had drum.
The '72 window sticker has a high serial number.
It's possible (pure speculation) that late in the '72 production run there were more disc spindles in stock than drum. Maybe Chrysler was trying to use up the extra disc spindles by making them std on the late production '72 340 models. Both spindles were not needed for '73 production as the drum and disc spindles were different along with the upper A-arm.
edit;
RAII, you not doing yourself any favors with your sig line.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195231
11/12/16 04:14 PM
11/12/16 04:14 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Why the hardon for Barry?
Re: Disc brakes on Duster 340's [Re: Cab_Burge] #2195232
11/12/16 04:15 PM
11/12/16 04:15 PM
Massachusetts
Massachusetts
Just trying to get the correct answers ... That simple.
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: formula_s] #2195233
11/12/16 04:16 PM
11/12/16 04:16 PM
Massachusetts
Massachusetts
I would never dishonor him on a public forum .... I also do not want his opinion ..... If you must know, PM me...
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: B5 Bee] #2195236
11/12/16 04:19 PM
11/12/16 04:19 PM
Massachusetts
Massachusetts
edit;
I am looking for concrete answers .... As far as my sig line , PM me I will explain....
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195242
11/12/16 04:40 PM
11/12/16 04:40 PM
Post all you want anywhere you want. What Bee said, Ma was known for using up stocks of what was on hand as it is about efficiency/making a profit/keeping the lines moving/maximum output & that is all good.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195243
11/12/16 04:40 PM
11/12/16 04:40 PM
Massachusetts
Massachusetts
OK so here are 2 window stickers from 1972 Dusters .. One says Power disc and the other does not list disc at all as standard equipment .... THREE40, I also thought the same as you in your fist post and now I too am confused as to 1972's.
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: Three40] #2195245
11/12/16 04:43 PM
11/12/16 04:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the 1972 dealer code book shows power brakes & disc brakes to be OPTIONAL on Duster 340
scope but, it must have been confusing enough for someone to write "optional" on the copy I have
I have a b'cast sheet for a 11/24/71 - SPD, US spec. HAMTRAMCK Duster 340 - it is coded "B11" - drum brakes
here's a copy of a window sticker for a 12/12/71 - SPD, US spec. HAMTRAMCK Duster 340 - it states "power disc brakes" - STANDARD
IMO questions were probably raised why the disc brakes were no longer STANDARD & a change was made during the 1972 Duster 340 model year shruggy late-November or early-December (based on the few pieces of info in this thread)
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195248
11/12/16 04:53 PM
11/12/16 04:53 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the first window sticker is a reproduction with errors spank part of the "problem" adding to the confusion
Re: Disc brakes on Duster 340's [Re: 6bblgt] #2195249
11/12/16 04:53 PM
11/12/16 04:53 PM
Massachusetts
Massachusetts
THANK YOU 6BBLGT .... I had assumed exactly what you have shown but I was looking for a explanation .... SO, It now seems that a 1972 Duster could have come WITH or WITHOUT disc brakes as Standard equipment...
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: 6bblgt] #2195251
11/12/16 04:54 PM
11/12/16 04:54 PM
Massachusetts
Massachusetts
AND I found that on this Site ....
Thanks in advance.
Re: Disc brakes on Duster 340's [Re: RAII4-speed] #2195257
11/12/16 05:05 PM
11/12/16 05:05 PM
Ca
branded Offline
branded  Offline
Ca
Page 1 of 3 1 2 3
