9 1/4" rear? posi? #2195083
11/12/16 10:26 AM
11/12/16 10:26 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I have a 76 Van I'm parting out.
Its loaded and leaving for the crusher this morning.
I took the rear end cover off last night to pull the pin to save the 11" backing plates and drums as a set.
It has a sure grip(?) posi in it and a 3.55 gear. I spun the threaded insert on the pass side back but the drivers side wont spin back.
Even though the center is loosened up and the yoke removed it won't come out? Any ideas...?
Are the gears and posi worth saving? Haven't heard of anyone looking for them... shruggy
...FAFO...
Re: 9 1/4" rear? posi? [Re: skicker] #2195088
11/12/16 10:53 AM
11/12/16 10:53 AM
canada
BareAssBob Offline
BareAssBob  Offline
canada
I would take the whole rear end out the dana 60 is a superior rear it is easy to change over to a car and easy to narrow if needed Dana calls there setup a sure lock and a 3.55 is one of the better gear ratios for the street .
Re: 9 1/4" rear? posi? [Re: skicker] #2195090
11/12/16 10:54 AM
11/12/16 10:54 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You need a case spreader to pull the center section out.
Don't be the exception.
Re: 9 1/4" rear? posi? [Re: skicker] #2195096
11/12/16 11:04 AM
11/12/16 11:04 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
You say 9 1/4 so I would try to back that bearing adjuster off so the carrier will clear to come out. I'm assuming you loosened the bearing caps to help spin that adjuster out?
Re: 9 1/4" rear? posi? [Re: skicker] #2195176
11/12/16 02:35 PM
11/12/16 02:35 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I just did the 9-1/4 in my Ram. The adjusters thread into the axle tubes. There's not much room to work with, but I got them loose enough to get the carrier out by tapping them with a small center punch. The special adjuster tool makes it a ton easier though.
Re: 9 1/4" rear? posi? [Re: BareAssBob] #2195260
11/12/16 05:11 PM
11/12/16 05:11 PM
canada
BareAssBob Offline
BareAssBob  Offline
canada
sorry disregard my last post I mistook the 91/4 for a 93/4 .
Re: 9 1/4" rear? posi? [Re: BareAssBob] #2195353
11/12/16 09:04 PM
11/12/16 09:04 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
The tag on it said 3.21...The posi had a bunch of deep cuts in it from a bad pinion bearing maybe in the original 3.21's.
The gears were 3.55 that were in it. After really looking at it in the daylight the gears were sharp and in pretty bad shape. I saved the yoke and the backing plates and drums and junked the rest... bawling
I never would have used it and wasn't comfortable to re-sell it...Thx...
...FAFO...
Re: 9 1/4" rear? posi? [Re: BareAssBob] #2195955
11/13/16 11:08 PM
11/13/16 11:08 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Apparently so did others, judging by the "case spreader" comment above. You turn the adjusters back and the case rolls out.
As to 9 1/4's in general - once I repaired them the first time for the typical pinion bearing/seal issue, I've never had to touch them again. And I certainly never throw out a 9 1/4 sure grip, or whatever we are calling them this week. twocents
Free advice and worth every penny...
Factory trained Slinky rewinder.........
