Dodge Ram, 5.9 Magnum: engine will not rev up
#2194902
11/11/16 07:26 PM
11/11/16 07:26 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
2001 Ram 2500, 5.9 Magnum. Intake was pulled to do the plenum gasket: ran perfect but was sucking oil. No other issues. One owner truck, religiously maintained, 150K miles. As part of the job, all the O-rings on the injectors, all the throttle body gaskets, etc. were done. Dizzy was removed and replaced- indexed where it was prior to removal. Everything has been re-assembled, all connections double checked, etc. Upon initial start up after the job, the truck runs/idles at 600rpm smoothly- but will not rev when throttle is moved. No apparent codes. What next to check? MAP, AIC and TPS connections have been checked. Thanks in advance.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Dodge Ram, 5.9 Magnum: engine will not rev up
[Re: EWJ]
#2194908
11/11/16 08:02 PM
11/11/16 08:02 PM
EWJ
Back in NJ....
Got it- makes sense. We'll try that tomorrow. Thanks.
[Re: EWJ]
#2195029
11/12/16 01:34 AM
11/12/16 01:34 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
You don't have the throttle cable hooked up or hooked up properly. The throttle cable must go under the black cable guide on the throttle body lever. There is no learn procedure for the throttle on a 5.9 magnum.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#2195040
11/12/16 02:05 AM
11/12/16 02:05 AM
Posts: 18,682 Fresno, CA
Jim_Lusk
Fresno, CA
You don't have the throttle cable hooked up or hooked up properly. The throttle cable must go under the black cable guide on the throttle body lever. There is no learn procedure for the throttle on a 5.9 magnum. This. I've made that same mistake.
[Re: Jim_Lusk]
#2195056
11/12/16 03:22 AM
11/12/16 03:22 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
You don't have the throttle cable hooked up or hooked up properly. The throttle cable must go under the black cable guide on the throttle body lever. There is no learn procedure for the throttle on a 5.9 magnum. This. I've made that same mistake. Yep I did also and I bet thats it. Ron
[Re: 383man]
#2196030
11/14/16 03:11 AM
11/14/16 03:11 AM
EWJ
Back in NJ....
The issue was the dizzy not in correctly, as much as he marked it before removal. There is a fuel sync aspect, which relies on the dizzy being in proper time. Up and running now. Thanks all for the suggestions.
[Re: EWJ]
#2196640
11/15/16 04:58 AM
11/15/16 04:58 AM
383man
Balt. Md
The issue was the dizzy not in correctly, as much as he marked it before removal. There is a fuel sync aspect, which relies on the dizzy being in proper time. Up and running now. Thanks all for the suggestions. Thats good. Usually when the dist was out of sync the eng would start to miss around 2000 rpm. Ron
[Re: EWJ]
#2196684
11/15/16 11:45 AM
11/15/16 11:45 AM
71yelladustr
Missouri U.S.A.
Just for future reference there is no reason to remove the distributor to remove the intake manifold. Glad you found your problem though.
