Page 3 of 5 1 2 3 4 5
Re: Billet valve covers [Re: AndyF] #2068687
05/07/16 02:28 AM
05/07/16 02:28 AM
AndyF Online content OP
AndyF  Online Content OP
I talked to the guys at Ultra Pro today and it turns out that they have built SB Mopar covers before. They build them for Stanton and they are super lightweight. Sounds like they are for sprint car stuff so probably a W8 or W9 type head.
Re: Billet valve covers [Re: AndyF] #2073962
05/15/16 05:30 PM
05/15/16 05:30 PM
I painted a pair of the covers just to see how it looks. I like the painted version better than the bare aluminum but some people might prefer the shiny look.
Re: Billet valve covers [Re: AndyF] #2074120
05/15/16 09:29 PM
05/15/16 09:29 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Paint kills the "billet bling" effect. At a glance they look like my no-logo Indy cast covers with paint.
Re: Billet valve covers [Re: BradH] #2074157
05/15/16 10:06 PM
05/15/16 10:06 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
I like painted valve covers as well. No bling required....
Re: Billet valve covers [Re: AndyF] #2074182
05/15/16 10:27 PM
05/15/16 10:27 PM
Idaho
Runner Offline
Runner  Offline
Idaho
hey cc dave, on your breathers, where did you get those? i know mancini used to sell them but havent been able to find any recently.
Re: Billet valve covers [Re: Runner] #2098311
06/26/16 03:15 AM
06/26/16 03:15 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
These are my first set.They weigh in around 1000 grams each, much lighter than the cast units. These ones are going on a 572 my friend is building.
I'm making the next ones taller to clear Jesel and T&D rockers.
W8 covers aren't far away, I'm doing some standard covers for myself, just some SBM units. I've been approached to do some P7 covers as well.
Alan Jones
Re: Billet valve covers [Re: AndyF] #2098415
06/26/16 11:29 AM
06/26/16 11:29 AM
Mo.
racerx Offline
racerx  Offline
Mo.
^^^Those looking good^^^
Re: Billet valve covers [Re: ccdave] #2098828
06/26/16 10:16 PM
06/26/16 10:16 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
. Who makes those valve covers and breathers?
Getting old just means you were smarter than some and luckier than others.
Re: Billet valve covers [Re: dannysbee] #2113601
07/19/16 09:39 PM
07/19/16 09:39 PM
LA360 Offline
LA360  Offline
A set I have done for Mike Gray, I've got to do some W8 covers for him next
Alan Jones
Re: Billet valve covers [Re: AndyF] #2113785
07/20/16 02:17 AM
07/20/16 02:17 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Purdy smile
Re: Billet valve covers [Re: AndyF] #2194486
11/11/16 01:20 AM
11/11/16 01:20 AM
I made a second version of the billet valve cover with a clear top based on some lessons learned from the first version. The gen 2 valve cover is a little lighter and I moved a couple of bolt holes so it would line up better with multiple cylinder heads. I found out the hard way that Trick Flow, Edelbrock and Ma Mopar put the bolt holes in different places.
Re: Billet valve covers [Re: AndyF] #2194537
11/11/16 02:40 AM
11/11/16 02:40 AM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
Andy do you have a store?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: Billet valve covers [Re: AndyF] #2194612
11/11/16 11:03 AM
11/11/16 11:03 AM
moparx Offline
moparx  Offline
andy, could you explain which holes you moved, and how much ? or did you slot a couple ? thanks !
beer
Re: Billet valve covers [Re: moparx] #2194746
11/11/16 01:50 PM
11/11/16 01:50 PM
Bottom ears are farther apart on Trick Flow heads than on stock heads. The difference is about 0.020 per side. I split the difference so my valve covers fit both. I don't really care about OEM heads but I figure I can't get too far away from that dimension since someone might make a head to OE specs that I do care about.
Re: Billet valve covers [Re: HOTMOPR] #2194747
11/11/16 01:53 PM
11/11/16 01:53 PM
No I do not have a store. I do have a website though where you can see stuff that I've designed for Mopar engines. If you want to buy stuff that I make you can talk to folks like Hughes Engines, Mancini Racing, FHO, Best Machine, Scott Brown, Firm Feel or Mazzolini Racing.
Re: Billet valve covers [Re: AndyF] #2195347
11/12/16 08:50 PM
11/12/16 08:50 PM
I think I'm going to tweak the design a little bit to lay back the lower edge so I have more clearance between the exhaust manifold.
Re: Billet valve covers [Re: AndyF] #2195364
11/12/16 09:26 PM
11/12/16 09:26 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A little known fact about factory heads is that the valve cover bolt holes are not square to the rail. They are all tipped toward the intake side. Also the rail area where the bolts are drilled are also tipped. This means a flat surfaced valve cover will not sit evenly on a factory cast head. I realize these covers are not directed toward this end of the market, but thought I could pass this along.
Your idea to tip the covers away from the exhaust is a good one. There are cast aluminum covers out there that warp terribly when hot, then go back into shape when cool. Tipping them should prevent some of that issue.
Re: Billet valve covers [Re: Stanton] #2195410
11/12/16 10:28 PM
11/12/16 10:28 PM
oregon
greendart408 Offline
oregon
Originally Posted By Stanton
If you're going to all that trouble, you should incorporate channels for a spray system. I've been thinking about machining the tops off a set of cast covers and making a set of bolt-on plates that have oil passages machined in.
My sheet metal fab, w8 covers have a gun drilled outside flange, has all the spring oilers machined into the rail. Real slick setup.
Re: Billet valve covers [Re: AndyF] #2195465
11/13/16 12:11 AM
11/13/16 12:11 AM
Maryland
69RRGTX Offline
69RRGTX  Offline
Maryland
Those clear top cover are beautiful!
69 Road Runner, 69 GTX
Re: Billet valve covers [Re: AndyF] #2195549
11/13/16 02:14 AM
11/13/16 02:14 AM
Thanks. I like using them when dyno testing. Just a quick glance and you can see if everything is working like it should.
