Oil consumption question
#2191917
11/08/16 12:20 AM
11/08/16 12:20 AM
Posts: 1,581 Friendly, WV
wedgeheaded
Friendly, WV
I have an older 360 with low miles, 75,000. It was very original and leaked oil everywhere. I pulled the motor out and cleaned everything, added new seals and gaskets, along with new umbrella valve seals. I put it back together and it runs great but uses oil. I assumed my usage was leakage. The car smokes slightly on start up but doesn't seem to while driving, or so say my friends who were following me. The leaking is minimal now. So where is the oil going? It's been suggested that the valve guides may be bad, stuck rings, I'm not fouling plugs. I don't know where to look. Any ideas or magic you guys can share?
Re: Oil consumption question
[Re: wedgeheaded]
#2191921
11/08/16 12:23 AM
11/08/16 12:23 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Did you replace the valve guide SEALS?
They usually get brittle and fall apart.
If you did and it still smoke on start up then I'd look at guides.
[Re: wedgeheaded]
#2192020
11/08/16 04:18 AM
11/08/16 04:18 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
Are any of the spark plugs shiny? If so look at two things to start with, intake manifold gaskets sealed up properly and or stuck rings or loose valve guides or both If no shiny spark plugs look at the rings and guides first If it was a around town car with very little highway driving it may be stuck or gummed up rings or worn out due to being driven mainly when cold As already suggested, do the compression test both wet and dry to see what that shows you
[Re: poorboy]
#2192094
11/08/16 11:53 AM
11/08/16 11:53 AM
RapidRobert
it can burn a lot of oil and not be visible at the tail pipe. My thoughts. I think the rings/cyls are worn especially the oil rings which might show bad on a compression test. the valve stem seals were that brittle after only 75K?? I think it has had a very hard life. EDIT meant to say "might NOT show on a compression test"
[Re: wedgeheaded]
#2192412
11/08/16 09:34 PM
11/08/16 09:34 PM
Posts: 5,850 ohio
ruderunner
ohio
Fwiw, my 77 Wagoneer is my winter daily. Its literally a fill the oil check the gas vehicle.
It burns a quart every hundred.
Doesn't worry me a bit as it doesn't ping and HSS good oil pressure.
Angry white pureblood male
[Re: wedgeheaded]
#2192423
11/08/16 09:51 PM
11/08/16 09:51 PM
Supercuda
About to go away
About to go away
up yours
If it's burning a quart every hundred miles you must have zero mosquitoes near you. I had a 63 BelAir that went thru a quart about every 50 miles, but it was a leak. Timing chain was so sloppy it wore a hole in the cover. But what do you expect for a $250 beater?
[Re: wedgeheaded]
#2192528
11/09/16 12:13 AM
11/09/16 12:13 AM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
The 440 in my '67 Imperial would use a quart every 150-200 miles on the freeway, and it never visibly smoked. When it was rebuilt it was clear the valve guides were most of the problem.
[Re: Blusmbl]
#2192972
11/09/16 12:49 PM
11/09/16 12:49 PM
wedgeheaded
Friendly, WV
The 440 in my '67 Imperial would use a quart every 150-200 miles on the freeway, and it never visibly smoked. When it was rebuilt it was clear the valve guides were most of the problem. I'm leaning towards the guides, it's a 41 yr old motor. I want to try a different weight oil first just to see what happens before I get too crazy. Thing is, with winter coming on, my window of experimenting is closing. I have this car for sale and don't want to sell it this way. It just runs too good to be anything serious, and not a big enough issue to warrant a full rebuild. I'm also leaning towards a set of the refurbished Aeroheads from Indy. $499 for new valves, guides, sprigs, decked and ready to go. Or, I'll just knock $499 off the price. That would fix the guide issue, if that's my problem, and give me some extras as well.
[Re: wedgeheaded]
#2192988
11/09/16 01:18 PM
11/09/16 01:18 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
My 2006 Magnum with the 3.5 v6 uses a quart between oil changes. It has done this since new - and currently has 212,000 on it. I just add oil in the middle of the oil change mileage.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: wedgeheaded]
#2193102
11/09/16 03:46 PM
11/09/16 03:46 PM
Posts: 10,585 Freeport IL USA
poorboy
Freeport IL USA
The 440 in my '67 Imperial would use a quart every 150-200 miles on the freeway, and it never visibly smoked. When it was rebuilt it was clear the valve guides were most of the problem. I'm leaning towards the guides, it's a 41 yr old motor. I want to try a different weight oil first just to see what happens before I get too crazy. Thing is, with winter coming on, my window of experimenting is closing. I have this car for sale and don't want to sell it this way. It just runs too good to be anything serious, and not a big enough issue to warrant a full rebuild. I'm also leaning towards a set of the refurbished Aeroheads from Indy. $499 for new valves, guides, sprigs, decked and ready to go. Or, I'll just knock $499 off the price. That would fix the guide issue, if that's my problem, and give me some extras as well. Knock the $500 off the price. Installing new heads on a 75,000 short block opens up the chance of pulling oil up past the rings. Tell the buyer the car burns oil, most somewhat expect old cars to use oil. Gene
[Re: dvw]
#2193829
11/10/16 11:43 AM
11/10/16 11:43 AM
wedgeheaded
Friendly, WV
Pretty sloppy guides will seal with new seals for awhile. My bet is the intake gaskets leak or the oil rings are gummed up and stuck in the grooves. Doug Stock iron heads and a stock iron square bore intake. I never even considered that my intake might be leaking. I'll look into that.
