Page 4 of 18 1 2 3 4 5 6 17 18
Re: T/A Challenger Replica Project [Re: Finoke] #219071
04/27/10 01:01 PM
04/27/10 01:01 PM
Tenn.
jrwoodjoe Offline OP
Tenn.
Now that spring is here, things are moving on the project again. Unfortunately, it is not where I hoped it would be. It was supposed to have gone to the painter/bodyguy last fall but (in short) he hosed me. Since he flaked out, I had to find another guy/team that would do the work the way I wanted. After talking with several shops, I ended up talking to a local guy. I saw some of his work several years ago and felt that I would not be able to afford him. Well, I was wrong. He is in my budget and turns out is building a 70 Charger R/T 440 car for himself. Things do happen for a reason. I know this guy will do a good job and he should begin working on it around July. Meanwhile, we decided to have some sheetmetal work completed (original body guy was going to do fab stuff too) to keep things on schedule. So all rust repair is being handled by another capable guy as I type this.
I Picked up the passenger fender today. At some point the original 70 fender had been replaced with a 71 fender. In this "before" pic., you can see the cut-out and arrows showing where the hood bumper needed to be relocated.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219072
04/27/10 01:02 PM
04/27/10 01:02 PM
Tenn.
Tenn.
And here's the "after". Hope to have more progress pics coming in the days and weeks to follow.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219073
04/28/10 08:30 AM
04/28/10 08:30 AM
cataclysm80 Offline
cataclysm80  Offline
Good to see you working on this again Joe. That 71 to 70 fender conversion looks great! I think the screw hole for the hood pin lanyard also moved just a little 70 to 71. You could compare your fenders. most people would never notice, but it is visible if you're paying really close attention.
Tav
Re: T/A Challenger Replica Project [Re: cataclysm80] #219074
04/30/10 01:14 PM
04/30/10 01:14 PM
Tenn.
Tenn.
Thanks for the heads up TAV. He needs to do one more thing to the fender that I had found and I will make sure to double check that hole as well.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219075
04/30/10 01:37 PM
04/30/10 01:37 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Looking good Joe! I love making them modifications from year to year. Your doing a nice job on that car!
I'm working on a 70 road runner that came with a 68/69 door. Same thing, did some modifications to make it work.
Re: T/A Challenger Replica Project [Re: Finoke] #219076
05/02/10 09:12 AM
05/02/10 09:12 AM
Tenn.
Tenn.
Thanks Tom. I'm hoping to make some real progress over the next 3 months. Other than the paint and bodywork, I still have a few major tasks. I need to rebuild the rear axle, steering column, and suspension. Also need to polish the bright trim.
65 Barracuda
70 Challenger
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219077
05/02/10 09:20 AM
05/02/10 09:20 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Will you be rebuilding the rear yourself? I've always been afraid to try that.
Re: T/A Challenger Replica Project [Re: Finoke] #219078
05/04/10 02:54 PM
05/04/10 02:54 PM
Tenn.
Tenn.
I can do everything except rebuilding and setting up the pumpkin. I bought a used sure-grip unit and have a new set of 3:55 gears. I'll probably pull the axles and take the pumpkin with the sure-grip to someone local. I'll have them install the new gears, put in new bearings and set the backlash. I'll pull the axles, put in new bearings and reassemble everything. Once it's back together, I'll paint and detail the whole assembly.
Joe
65 Barracuda
70 Challenger
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219079
05/07/10 06:56 AM
05/07/10 06:56 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Joe
I like that. I might do that next time. Doing it this way gets your feet wet on how things work back there
Re: T/A Challenger Replica Project [Re: Finoke] #219080
06/04/10 01:05 PM
06/04/10 01:05 PM
Tenn.
Tenn.
Few more progress pics. The trunk lid on the car is pretty nice but had breakthrough rust in one area of the lip. Here is a shot of rust after blasting on the inside of the trunk lid.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219081
06/04/10 01:07 PM
06/04/10 01:07 PM
Tenn.
Tenn.
And and after shot of the repair done with new sheet metal welded in. The cutout shape around the hole is not perfect but is pretty close.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219082
06/04/10 01:08 PM
06/04/10 01:08 PM
Tenn.
Tenn.
Here's what the rust looked liked on the outside lip of the same area.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219083
06/04/10 01:09 PM
06/04/10 01:09 PM
Tenn.
Tenn.
And here's the after.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219084
06/05/10 08:54 PM
06/05/10 08:54 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Looks good Joe. It matches your description perfectly.
Re: T/A Challenger Replica Project [Re: JDMopar] #219085
06/06/10 09:02 AM
06/06/10 09:02 AM
Tenn.
Tenn.
Thanks Jackie. It was great meeting Mrs. JDMOPAR and hanging out with you guys.
Here's a photo of the rust that was in the bottom of the passenger door after blasting.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219086
06/06/10 09:04 AM
06/06/10 09:04 AM
Tenn.
Tenn.
And a photo after being repaired by my Metal Guy.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219087
06/08/10 11:09 AM
06/08/10 11:09 AM
Tenn.
Tenn.
Here's a shot of the driverside front fender. You can also see some "kittyhair" filler on the top of the fender. I had some other rust repaired when I first started this project. For some reason they slapped that on instead of skimming it. I had my new guy sand it down to make sure something wasn't hiding there. Turns out it was fine. My goal is to have minimal filler on the car.
You can see some "jagged" rust where the metal overlaps at the fender mounting flange. This was not repaired before and I had the new guy fix it. This is the before shot.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219088
06/08/10 11:11 AM
06/08/10 11:11 AM
Tenn.
Tenn.
Here's the after repair. It will get seam sealer on the edge as came from the factory.
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219089
07/16/10 09:09 AM
07/16/10 09:09 AM
Tenn.
Tenn.
Now that all the removable panel rust repair has been competed, it is time to do the body shell. It left yesterday for rust repair and I'll update with those pics as I can. With the car gone, the garage can get reorganized and I'll have room to work on some of the other resto. tasks that need to be done.
Joe
65 Barracuda
70 Challenger
Re: T/A Challenger Replica Project [Re: jrwoodjoe] #219090
07/30/10 10:50 PM
07/30/10 10:50 PM
Tenn.
Tenn.
Thought I'd post a couple of progress pics taken today along with the "before" shots. Here is the before shot of the right driverside cowl area.
