Heavy rear for mid 80's ram charger? #2189472
11/04/16 02:49 PM
11/04/16 02:49 PM
London Ontario Canada Eh
Dono Offline OP
Dono  Offline OP
I am afraid that if I do a big block swap in my mid 80's ram charger that rear will not take the torque. Is there a dana out there I can look for that will work and if I can fit more rubber under all the better.
Cheers Don.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2189532
11/04/16 04:45 PM
11/04/16 04:45 PM
dogdays Offline
dogdays  Offline
You will find Dana 60s under 3/4 ton Dodge trucks of those same years. That's where I'd go, use the entire axle and change wheels.
R.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2189698
11/04/16 09:59 PM
11/04/16 09:59 PM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
The big rear axle from the factory was the 9.25. Small axle was the 8.25.
Rumor of some 5 lug Dana 60's used in 70s vintage big block trucks but I've never seen one. Most Dana 60 are 8 lug.
Unless you're making lots of power the 9.25 should be adequate, I'd upgrade to a crush sleeve eliminator.
Angry white pureblood male
Re: Heavy rear for mid 80's ram charger? [Re: ruderunner] #2189712
11/04/16 10:14 PM
11/04/16 10:14 PM
IN
ahy Offline
ahy  Offline
IN
Agree the 9.25 should take it fine as long as you are running street tires.
If you will run slicks or plan on mud bogging with heavy rubber different story.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2189765
11/04/16 11:15 PM
11/04/16 11:15 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think the 5 lug dana 60 were used only by IH------94-01 mexican ramchargers use a heavy duty dana 44---at about 120k my 2000 mexican spit out the dana 44--i upgraded to a 2002 9.25 disc brake from a 1500 truck.....bob
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2189929
11/05/16 11:01 AM
11/05/16 11:01 AM
ohio
ohio
IH, Ford and Jeep used them in late 60's and early 70's heavy halfton.
An 8 ug 60 rear can be bolted in, but you'd need different wheels front and back unless you swapped the front to 8 lug as well
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2190467
11/06/16 01:07 AM
11/06/16 01:07 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
there are guys running dana 60 front and rears on the ramchargers too----my son is running dana 60,s on his dakota---where there is a will there is a way...
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2190558
11/06/16 10:44 AM
11/06/16 10:44 AM
ohio
ohio
So we get to the question of2 or 4 wheel drive?
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2194276
11/10/16 09:53 PM
11/10/16 09:53 PM
Dono Offline OP
Dono  Offline OP
Yes I guess I didn't mention that she is only a 2 wheel drive with a 360 now. I would like to drop in a big block.... because I have a few and I can. Just afraid the rear will not take it. I don't expect to run much more then street tires but you know the track will call.. it always dose with a new build.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2194469
11/11/16 01:09 AM
11/11/16 01:09 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
when chrysler designed the 9.25 they wanted it just as strong as the dana 60---they fell just short in that the c-clip axles have a built in fail point----but the mopar c-clip is massive compared to most----i keep expecting to see lots of gm and fords with roller bearings and c-clips littering the highways----but it isnt the case....
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2194507
11/11/16 01:39 AM
11/11/16 01:39 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The loads on the "C" clip axles at the C clip probably isn't very high under normal conditions. If you are circle tack racing, or doing hard corners on blacktop, constantly, the C clip may be a weak point, at some point, maybe.
Probably the weakest point on a 9 1/4 is the axle bearings running on the axle surface, or the crush sleeve at the pinion gear collapsing and allowing the drive shaft flange to loosen up and drop the pinion back into the housing. Those are the two most frequent failures I've seen on Mopar 9 1/4 rear ends, and for as many of these rear ends as I've seen, it probably wasn't much of an issue.
I would not be concerned with a 9 1/4 under a Ramcharger with a big block, unless drag racing was the main intended purpose. Regardless of the opinion of many on this board, a 9 1/4 is a tough rear end. Gene
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2194622
11/11/16 11:28 AM
11/11/16 11:28 AM
Dono Offline OP
Dono  Offline OP
Funny the main target for the demo derbys is to hit the rear tires hard from the side to pop the C clip off. The next turn they make the axle slides right out.
Sooo there should be a 9 1/4 under here then eh?
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2194727
11/11/16 01:31 PM
11/11/16 01:31 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i think the biggest problem on the 9.25 is that guys re-use the crush sleeve---you only get to torque it once---thats why those stretch bolts are used on heads--you gotta throw them away---use the solid sleeve-----and if you are planning on the demo derby give one of us guys a chance at rescuing the dog before you put it down....dodge...
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2195038
11/12/16 01:57 AM
11/12/16 01:57 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Dono, OK, so I ASSUMED the guy wasn't going to enter his truck in a demo derby, or I would have included that with the disclaimer of circle track racing, and consistently doing hard cornering on blacktop.
Thanks for the tip on demo derbying a 9 1/4 though. Should I decide to enter one with a 9 1/4, I will add the extra step to build up the ends of the C clips so they won't fall out. How many times to they take a direct hit before they fall out anyway?
Under normal driving conditions, and a few trips to the drag strip from time to time, YES, I see no reason a 9 1/4 shouldn't be under that Ramcharger. Gene
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2195157
11/12/16 02:02 PM
11/12/16 02:02 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i have a narrowed 9.25 to A body width with 8.75 axle ends to eliminate the C clip---you have to buy a custom axles for it-----drag race guys have to use a C clip elimination kit and the ford 9 inch axle end is the most common one to use--(-you can use 8.75 axle ends also like i did)----my axle runs a 2.7 posi that i first envisioned as a bonneville axle for my 64---it now is under my 50 hudson as a cruiser set up......
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2196958
11/15/16 09:34 PM
11/15/16 09:34 PM
Dono Offline OP
Dono  Offline OP
Cool so you use the green bearings and no thrust block 9.25" splines with 8.75" shaft dimensions and bearings.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2197046
11/15/16 11:19 PM
11/15/16 11:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I bought a 87 ramcharger new with a dana 44 in front and a 9.25 in the rear with 3:55 gears, small painted steelie rims and small tires. It had a 360 with 4 barrel quadrajet carb from the factory.
As soon as I got it within a couple weeks I put a 3" rough county suspension lift on it, installed 4:11 gears front and back, Big heavy steel rims with 33.5" tires on it and nitrous oxide under the quadrajet. It ran 14.5 seconds in the quarter mile with the nitrous at the drag strip numerous times. I was just as fast as the stock 5.0 mustangs of the day and had a blast racing my buddies in there stangs.
I beat the crap out of that truck for 7 years and 89K miles before I sold it. I towed a 21 boat with it for a few years 4 plus hours to lake Cumberland about twice a month. Neither diff ever went out and I know the guy I sold the truck to and he still has it.
The drag strip deal was not easy on the truck, I would do 4 wheel drive smokey burnouts on nitrous and then race it in 2 wheel drive. I also raced in the sand at the sand drags but that is real easy on the diffs in the sand.
Everyone said I would blowup the motor but never did. Was a crowd favorite.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2199193
11/20/16 12:20 AM
11/20/16 12:20 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Mexico received D60 rears in 5lug. Otherwise trucks only had 8lug D60s for Dodge.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2199864
11/21/16 12:03 PM
11/21/16 12:03 PM
Dono Offline OP
Dono  Offline OP
My Ram charger I am speaking about is only two wheel drive with a 360 motor and has 5 on 5 all around.
Re: Heavy rear for mid 80's ram charger? [Re: Dono] #2199909
11/21/16 01:09 PM
11/21/16 01:09 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
here is hoping your rear is a 5 on 5.5----and either you go to a stock dodge truck 9.25 or pony up money to have someone build you a custom dana 60.....
