01 Dakota CK engine light... #218927
02/09/09 04:53 PM
02/09/09 04:53 PM
Texas
BigTexasFury Offline OP
Texas
My 01 Dakota's ck engine light is coming on intermittently and gives out the code (going by memory here) P01601 (?).
It's the right rear oxygen sensor...
If it goes, it goes. right? Why intermittent? Thanks...
"To finish is to win." Josh Billings
Re: 01 Dakota CK engine light... [Re: BigTexasFury] #218928
02/10/09 10:25 PM
02/10/09 10:25 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
My 97's does that. It'll come on, then a week or so later, goes out. Truck runs the same either way. I had a 93 w/a bad O2 sensor, you'll know when it goes south.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
