1977 440 noise #2188729
11/03/16 02:14 PM
11/03/16 02:14 PM
Alabama
dodgedart67 Offline OP
Alabama
I have a 1977 440, freshened up with new rings, rod bearings, main bearings, cam bearings, cam, lifters, timing chain, etc...
It has roughly 3-4000 miles on it now, cold oil pressure with 10w30 bit almost 80, runs down the road warm at 60-70,
Now all of a sudden it has developed a knock under load over 2000 rpm, oil pressure never changes and stays good, checked torque converter bolts, flex plate for crack, exhaust, everything is in order, it will not make any noise in park of neutral up to 4000 rpm, any help of advice greatly appreciated.
Re: 1977 440 noise [Re: dodgedart67] #2188762
11/03/16 02:56 PM
11/03/16 02:56 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
What happens if you get up to speed on the road, pop it into neutral and kill the engine?
Re: 1977 440 noise [Re: dodgedart67] #2188878
11/03/16 05:45 PM
11/03/16 05:45 PM
Alabama
Alabama
I'll try that and see what happens, I'll post later
Re: 1977 440 noise [Re: dodgedart67] #2189383
11/04/16 12:56 PM
11/04/16 12:56 PM
Alabama
Alabama
Got up to about 60, put in neutral and cut it off and everything just went quiet
Re: 1977 440 noise [Re: dodgedart67] #2189508
11/04/16 03:58 PM
11/04/16 03:58 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Header gasket
Re: 1977 440 noise [Re: dodgedart67] #2189554
11/04/16 05:44 PM
11/04/16 05:44 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Had this problem with a ford one time, spark plug was louse, never happened again.
Have a great day
Iowan
"obsolete is neat"
Re: 1977 440 noise [Re: dodgedart67] #2190665
11/06/16 01:24 PM
11/06/16 01:24 PM
Alabama
Alabama
Headers don't leak at all, new gaskets on heads and collectors, all plugs ok, I just don't understand why it doesn't do it sitting still while revving the engine
Re: 1977 440 noise [Re: dodgedart67] #2191136
11/07/16 01:02 AM
11/07/16 01:02 AM
can you either power brake it or run it up on stands to see if you can get it to recreate?
Re: 1977 440 noise [Re: dodgedart67] #2191185
11/07/16 02:17 AM
11/07/16 02:17 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Is it spark knock? You mention it needs a load on it to happen.
Have you looked at the plug wires? Maybe a bum set is letting 5 and 7 cross.
I want my fair share
Re: 1977 440 noise [Re: dodgedart67] #2192087
11/08/16 11:46 AM
11/08/16 11:46 AM
Alabama
Alabama
Haven't had a chance to mess with it for a couple days but it has a new set of 8.5mm wires on it
Re: 1977 440 noise [Re: dodgedart67] #2192366
11/08/16 08:24 PM
11/08/16 08:24 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Check your firing order real close easy to mess them up especially 5 7.
Check the distributor cap and dizzy itself too.
Re: 1977 440 noise [Re: dodgedart67] #2196106
11/14/16 12:02 PM
11/14/16 12:02 PM
Alabama
Alabama
Firing order is correct, is starts and runs as it should, put it on the lift and ran it up to highway speed with a buddy underneath checking for noises and nothing with wheels in the air so it has to be something not engine or trans related I'm thinking
