Tony s tip of the week #2188417
11/02/16 11:25 PM
11/02/16 11:25 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
I want to try and contribute more knowledge to this forum, so here goes:
This winter put windshield washer fluid in your cooling system. It's rated for -20* and in the summer it's legal for the track ....I know some guys don't even remove it
....BAD A$$ STREET CAR.....
Re: Tony s tip of the week [Re: n20mstr] #2188424
11/02/16 11:34 PM
11/02/16 11:34 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Thanks Tony. Great tech tip.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Tony s tip of the week [Re: n20mstr] #2188428
11/02/16 11:38 PM
11/02/16 11:38 PM
up bow Great TIP devil
Re: Tony s tip of the week [Re: n20mstr] #2188433
11/02/16 11:43 PM
11/02/16 11:43 PM
P
Porter67 Offline
Porter67  Offline
P
Are you being serious?
Re: Tony s tip of the week [Re: Porter67] #2188440
11/02/16 11:50 PM
11/02/16 11:50 PM
PA.
"Little"John
"Little"John
PA.
Nice to see you stopping in more often. We now nave a sticky in the race section for power adders that you can go in and start a post. May I suggest some nitrous tips and progressive settings for a start.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Tony s tip of the week [Re: pittsburghracer] #2188444
11/02/16 11:59 PM
11/02/16 11:59 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
LMAO!
I'm glad you finally started contributing here...
'63 Dodge 330
11.19 @ 121 mph
Re: Tony s tip of the week [Re: n20mstr] #2188454
11/03/16 12:11 AM
11/03/16 12:11 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Boiling point of a typical -20F washer fluid (31% methanol by weight) is only about 170F. If you're not running a 160 thermostat you'll have lots of pressure in your cooling system... doesn't sound like a great idea.
Re: Tony s tip of the week [Re: DrCharles] #2188477
11/03/16 12:38 AM
11/03/16 12:38 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Not recommended for daily drivers. Just race cars that want to have some a/f for winter temps, and something that if there is some residual left in there the track won't kick you out for it !
Re: Tony s tip of the week [Re: pittsburghracer] #2188478
11/03/16 12:39 AM
11/03/16 12:39 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
lol , maybe but then I don't want to put it all out there.....lol
Re: Tony s tip of the week [Re: Porter67] #2188480
11/03/16 12:41 AM
11/03/16 12:41 AM
N
n20mstr Offline OP
n20mstr  Offline OP
N
Yes, lots easier to handle than green antifreeze. And easier to drain and go back to water in the race season
Re: Tony s tip of the week [Re: n20mstr] #2188483
11/03/16 12:44 AM
11/03/16 12:44 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Is this just a tip...or do you put the whole thing in? laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: Tony s tip of the week [Re: GY3] #2188521
11/03/16 02:10 AM
11/03/16 02:10 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If I get the tip started, the whole thing is following.
Re: Tony s tip of the week [Re: n20mstr] #2188531
11/03/16 02:36 AM
11/03/16 02:36 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
Better tell Bird to quit adding it to his race fuel!!!lol
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Tony s tip of the week [Re: n20mstr] #2188551
11/03/16 03:41 AM
11/03/16 03:41 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Won't that cause some corrosion?
Re: Tony s tip of the week [Re: 451Mopar] #2188575
11/03/16 09:20 AM
11/03/16 09:20 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Most of the guys around here drain the engine completely somehow....I find it difficult to get all the water out and then I worry it will rust and makes a big mess next year when you put water back in.
I just run antifreeze all year. Done it the last couple of years, and no one noticed....
Re: Tony s tip of the week [Re: DrCharles] #2188611
11/03/16 10:54 AM
11/03/16 10:54 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Doesn't pressure increase your boiling point....
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Tony s tip of the week [Re: Dragula] #2188613
11/03/16 10:56 AM
11/03/16 10:56 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
And your the guy everyone is cursing in the staging lanes when it gets on the track. Way to be inconsiderate of your fellow racer.
Re: Tony s tip of the week [Re: n20mstr] #2188626
11/03/16 11:16 AM
11/03/16 11:16 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
After the last race of the year, I dumped the water, put in antifreeze, and ran the water pump for a few minutes. Only took a half hour from unstrapping the car in the trailer to strapping it back in. Reverse the process next spring. My buddy just drained the water out a few years ago, and some water was trapped in the heads, and cracked them over winter. It caused a huge mess.
69 GTX 68 Road Runner
Re: Tony s tip of the week [Re: 1967dartgt] #2188633
11/03/16 11:38 AM
11/03/16 11:38 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Yes, they are related. The problem is that you have to have that increased pressure to keep your coolant from boiling whenever the temperature is at or above the boiling point. In other words the increased temperature causes the increased pressure, which is hopefully contained by your radiator cap.
If the temp leaving the block is, say, 180 then there will be places in the heads where it's probably closer to 200 (pulling figure out of the air here) whistling which will need a few psi to keep it from boiling. Don't know how many.
Anyway it's an interesting concept but I think I'll stick with antifreeze & water (and a required catch can)... shruggy
Re: Tony s tip of the week [Re: DrCharles] #2188645
11/03/16 11:58 AM
11/03/16 11:58 AM
PA.
"Little"John
"Little"John
PA.
Trying to be considerate of my fellow racers I don't and won't run antifreeze but I have dumped a gallon in at Norwalk after the Halloween Classic. I do this because one year I didn't get my car unloaded as soon as I planned from my car trailer and popped a freeze plug. I didn't do it this year because I am planning on one more test n tune before it gets placed in my heated shop. But I'm watching the weatherman VERY closely.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
