Re: Probably a dumb dana question
[Re: 1980volare]
#2188271
11/02/16 08:21 PM
11/02/16 08:21 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
Did you reuse the front shim pack that goes behind the front bearing? If so then it needs thicker front shim pack, if not put the old one back in and go from there. The Mopar FSM calls for 15 to 20 inch lbs. rotational torque on used bearings with no front seal with the pinion gear pointed straight up towards the sky, 20 to 25 lbs. with no seal on new bearings and races I shoot for the tighter set ups, not the looser specs. IHTHs
[Re: 1980volare]
#2188337
11/02/16 09:53 PM
11/02/16 09:53 PM
Posts: 298 mt. pleasant, PA
Diplomat440
mt. pleasant, PA
I bent my baffle behind the inner bearing cup knocking it out and had to get a new one. It was thicker, so I had to adjust my shim packs to compensate for it.
Any chance one of the outer shims got stuck to the bearing or fall off during disassembly and you didn't realize it? Same brand of bearings?
When I was shopping for a rebuild kit i noticed there were ones for front 60s that only came with a crush sleeve and no outer shims. Had to really compare some of em to know that I was getting what I needed. I ended up ordering a JEGS brand one. Came complete with two different pinion seals, plenty of shims, ring gear bolts, and Timken bearings.
