Can you use 2 cycle outboard oil as a lubricant in methanol?
I don't see why not just as long as you don't have go through fuel check at the races.
I sell VP M2 upper lub for methanol and it about that viscosity, IMO. Which don't mean sh!t!
Use at your own risk but I bet it won't hurt.
Upper lube helps, but does not make your alcohol fuel system maintenance free. Should still drain it and blow out alcohol fuel lines when not in use. We drained our fuel system after every race to prevent corrosion. Used plenty of WD40 too in our fuel system to store stuff. Spray it in and blow it through.
