Re: Radiator recommendation
[Re: 71birdJ68]
#2185573
10/29/16 10:24 PM
10/29/16 10:24 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
There is only one choice, Glen Ray radiators. If you still have the original, they can fix it, or make a repo that is just like it. Talk to them about their better cooling ones that look completely stock, I have on on my 528 and it never gets over 180 degrees. X2. Best in the business....
Admiration For Multiple Carburetor Vehicles...
[Re: gregok]
#2185697
10/30/16 07:50 AM
10/30/16 07:50 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
I don't have the original so will have to go repop. I will check them out, thanks for the info! Check them out? Best way to go on the planet, I have x6 of Bob's radiators in my ebodies cars.
[Re: gregok]
#2192837
11/09/16 07:49 AM
11/09/16 07:49 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I went with a U.S. Radiator triple pass 4 core, got it through Classic Ind. for my 572 Hemi.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: gregok]
#2195181
11/12/16 02:46 PM
11/12/16 02:46 PM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
I am gathering info to restore my 1970 440+ 6 non air cuda and was looking for your experience with stock radiators versus aftermarket aluminum ones. What size radiator was factory for this car? Thanks for any input. According to the '70 FSM, 26" was the factory size rad.
[Re: gregok]
#2195360
11/12/16 09:18 PM
11/12/16 09:18 PM
Posts: 29,679 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
What size radiator was factory for this car? 22" - If it does not have an optional high performance axle package. 26" with any optional high performance axle package. If your fender tag shows a 26 then 26" radiator.
[Re: gregok]
#2195415
11/12/16 10:36 PM
11/12/16 10:36 PM
Posts: 5,127 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Read what Barry has written and go to the car and measure the opening anyways. Run the factory Rad and a Rad Shroud that goes with the Rad and use a mated water pump and housing. I run a factory fan without the clutch. I loose a few HP but the Hemi runs at 163 Degrees no matter what the out side temperature is with a 160 high flow thermostat.
1971 HEMI E BODY REGISTRY
[Re: Alaskan_TA]
#2198858
11/19/16 11:15 AM
11/19/16 11:15 AM
moparfan53
NB, Canada
What size radiator was factory for this car? 22" - If it does not have an optional high performance axle package. 26" with any optional high performance axle package. If your fender tag shows a 26 then 26" radiator. Barry is correct. When I posted the FSM page, I did not notice there is a typo. Part# 2998960 is listed as both 22" and 26".
[Re: moparfan53]
#2198922
11/19/16 01:39 PM
11/19/16 01:39 PM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
What size radiator was factory for this car? 22" - If it does not have an optional high performance axle package. 26" with any optional high performance axle package. If your fender tag shows a 26 then 26" radiator. Barry is correct. When I posted the FSM page, I did not notice there is a typo. Part# 2998960 is listed as both 22" and 26". To make it easier for you: If your car is an Automatic with a 3.23. gear ratio it has a 22" radiator. All other 440+6 cars have a 26" radiator.
[Re: gregok]
#2200415
11/22/16 04:49 AM
11/22/16 04:49 AM
Posts: 714 California
BigDaddy440
California
If you're looking to restore your original, and you probably should being it's a six-pack car, Glen-Ray is the way to go. He did my small font "054" radiator, and it's perfect.
1969 A12 Roadrunner 1970 Plymouth Cuda 1968 Dodge Dart
