Re: Purchase one main bearing?
[Re: SlickRS23]
#2185338
10/29/16 03:32 PM
10/29/16 03:32 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
What motor, year model and what size main bearings are you wanting?
[Re: rumblebee4232]
#2186179
10/30/16 09:51 PM
10/30/16 09:51 PM
RapidRobert
I have a pair of RB thrust bearings you are welcome to. they are clevite 77 and are .001 US (probably a plus for you). they are new but have some slight rubbing damage that you can barely see in the pic at ~10 0'clock (not from being installed but knocked around in transit) & I think a slight touch up & there would not be an issue as it is around the corner so to speak from the bearing surface. they are the small thrust ones (OD in pic is ~3& 19/32"). they fit on my late 74 440 block this evening when I checked em but I could see that the block flanges were way wider than the bearing flanges. BB newbie but iirc narrow bearing flanges will fit narrow and wide block flanges but wide bearings need a later block with the wide flanges
