Re: Best BB Race Head for an A-body without having to fab header
[Re: Dragula]
#2184209
10/27/16 11:03 PM
10/27/16 11:03 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Why not the 572-13's? Yes, you need different pistons, and they really like a large bore, but they will work, just at higher rpm's.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
[Re: AndyF]
#2184776
10/28/16 06:53 PM
10/28/16 06:53 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
93E10 means you need to be down around 11:1 compression so that will kill 100 hp. Now you're down to around 750 hp with ported EZ heads. If that is enough power to hit your number then it seems like those would be a good choice for you. If you already have the EZ heads then I assume you also have headers that are working today? Yes and yes....I am not a race fuel guy, and the headers I have are beat, but I have found a new set I will order if money allows....The low deck worries me a little for header fitment, but I am definitely not going custom.. So I run around 10.8:1, might push to 11:1, and EZ275, EZ295, or 440-1's are my question. We will turn it to 6400rpm and launch around 2200...We have done well this way in a stock block, so I am curious if I should be looking at other heads or not.
