Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183843
10/27/16 03:54 PM
10/27/16 03:54 PM
Pennsylvania
P
P7 Engineering Offline OP
P
Pennsylvania
My three rough pieces.....
My 1974 2WD shortbed Chevy Truck build thread:
http://67-72chevytrucks.com/vboard/showthread.php?t=525098
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183844
10/27/16 03:55 PM
10/27/16 03:55 PM
Pennsylvania
P
P
Pennsylvania
This is the number 5 bearing.....(ID not honed to final size yet, and oil hole not drilled yet)
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183849
10/27/16 03:58 PM
10/27/16 03:58 PM
Pennsylvania
P
P
Pennsylvania
Here is #1 - #4. We then honed the ID to final size on the rod hone, using stones for aluminum. This had not yet been done in this pic. Also the oil feed through hole had not been drilled yet.
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183859
10/27/16 04:10 PM
10/27/16 04:10 PM
dogdays Offline
dogdays  Offline
Cute, very cute!
R.
Re: SB race block cam tunnel machined wrong [Re: dogdays] #2183868
10/27/16 04:35 PM
10/27/16 04:35 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
So you are using the aluminum as the bearing with no other bearing right?
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183883
10/27/16 04:50 PM
10/27/16 04:50 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Bronze not a suitable material?
Kevin
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183910
10/27/16 05:32 PM
10/27/16 05:32 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
How much press fit will you be using on those? I'm going to ask a possibly stupid question and ask if you took that into account when you finish honed the ID?
Re: SB race block cam tunnel machined wrong [Re: P7 Engineering] #2183960
10/27/16 06:22 PM
10/27/16 06:22 PM
Pennsylvania
P
P
Pennsylvania
I believe Ryan has them set up for 0.002 press. Yes, Ryan took the crush into account when honing. I know he said the #5 came right on where he wanted it after installing it.
Yes, this id the final bearing surface the cam will ride on.
You might be able to use Bronze, I don't know. Ryan researched what other people have typically done in the past for something like this, and they have been 850 alloy aluminum. High tin content. The oil clearance he said is typically set up looser than babit. He was shooting for 0.002-0.003 oil clearance, for this setup.
