Re: drive line length and pinion angle
[Re: orangemonster]
#218227
02/08/09 08:40 PM
02/08/09 08:40 PM
Your post is a little confusing, but here is a link to the Dana/Spicer website that has a program called Torsional Analysis where you can plug in your dimensions and angles and it will calc acceptable parameters for you. Hope it helps. http://www2.dana.com/expertforms/demenu.aspx
[Re: orangemonster]
#218230
02/08/09 10:00 PM
02/08/09 10:00 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I just installed some launcher springs on my 64 fury,and the front segment is 20 inches instead of 21.My new drive line was a bit to long in the first place,and now it is to short.How much engagement in the trans is required?Can I just cut off a couple of inches from the input shaft? My pinion angle is 5 degrees positive at the pinion,canI shim this 12 degrees or do I need to change my spring perches.The car sits lower than I would like,will longer shackes change the pinion angle?
Ok, as you said you have multiple issues. First off, drive shaft lenght, you'll need about 1" back out from the tail shaft. As you put on springs that are shorter on the front you'll need to do one of three things, put a spacer between the front of the spring to bring the drive shaft back to proper lenght. second, you could redrill th locating pin hole on the rear end spring perches to move the rear back, you'll probably need new u-bolts.Third is shorten the drive shaft, do not cut the output shaft on the trans. Pinion angle has to be down 2-4 degrees, you could shim it but if your correct on 5 up thats to much. Buy new spring perches cut off the old ones and rotate the rear to get the proper pinion angle then have it properly welded.You say the car sets to low, if you would make a shim to bring the spring back you could make it longer to drop the front of the spring, that would also change your pinion angle toward the down side. Hope this helped.
