Four-speed Hurst shifter identification #2173493
10/13/16 10:29 AM
10/13/16 10:29 AM
CA.
RAY1969CARS Offline OP
CA.
The only numbers I could find on it are 760113M thanks guys
Re: Four-speed Hurst shifter identification [Re: RAY1969CARS] #2173504
10/13/16 10:41 AM
10/13/16 10:41 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
There should be a number on the reverse lever under the box.
But anyway the only shifter box I remember that mopar used with a provision for a grease fitting to be installed ... the nut on the side of the box ... was in the 833OD equipped pickups of the 80's , not sure if they were used in F bodies ?
That box will directly swap into 66-69 B body and 67-72 A body, C bodies of the 60's , but not sure about E body with the slip in handle only ?
Mainstream Media is the new Pravda
Re: Four-speed Hurst shifter identification [Re: JohnRR] #2173507
10/13/16 10:43 AM
10/13/16 10:43 AM
CA.
CA.
That's what I've be using it on a 69 a body just want to make sure it will work
Re: Four-speed Hurst shifter identification [Re: RAY1969CARS] #2180319
10/22/16 01:07 PM
10/22/16 01:07 PM
New York
rarefish Offline
rarefish  Offline
New York
What is the small nut that is welded to the side of the shifter for? It is just to the right of the lettering. Some shifters have them some do not.
Re: Four-speed Hurst shifter identification [Re: rarefish] #2180322
10/22/16 01:15 PM
10/22/16 01:15 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Its mentioned above. Grease zerk.
Re: Four-speed Hurst shifter identification [Re: RAY1969CARS] #2180471
10/22/16 06:53 PM
10/22/16 06:53 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've got four of those. They all came out of OD-equipped vans...
Re: Four-speed Hurst shifter identification [Re: RAY1969CARS] #2181443
10/24/16 01:30 PM
10/24/16 01:30 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I put one in an A body I have, the only thing that seems different is the reverse lever? I had to change the adjustment on the reverse rod, all the way out to the end, on the one I used.
