518 into 70 cuda #218056
02/08/09 06:25 PM
02/08/09 06:25 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Im wanting to put a 518 automatic into my 70 cuda to cut back on highway rpm. Its going behind a mild 340. Just wondering what kind to look for. Some say lockup and some say not. And whats the best years? I know this has been talked about on here a lot but I read a lot of different opinions in the archives.
Re: 518 into 70 cuda [Re: derekeh] #218057
02/08/09 07:55 PM
02/08/09 07:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
94 and up was the electronic lockup if memory serves. The older ones didn't have lockup and the overdrive on the 94+ is electronically actuated but on the older ones was it electronic as well or was it hydraulically engaged/disengaged?
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218058
02/08/09 07:57 PM
02/08/09 07:57 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
my 94 ram has a 46rh..
so they probably went to electronic shift in either 95 or 96...which is a 46re
Tony
70 AARCuda Vitamin C
Re: 518 into 70 cuda [Re: 70AARcuda] #218059
02/08/09 08:03 PM
02/08/09 08:03 PM
Manitoba, Canada
Manitoba, Canada
The rh doesn't have the lockup does it? Only the re?
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218060
02/08/09 08:13 PM
02/08/09 08:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..the 46rh is a lock up.
Tony
Re: 518 into 70 cuda [Re: 70AARcuda] #218061
02/08/09 08:22 PM
02/08/09 08:22 PM
Manitoba, Canada
Manitoba, Canada
Electronic or hydraulic as well? What year was the first for the lockup then? I thought it was 94 but that's obviously wrong. But I thought the first few years of the 518 were overdrive w/o lockup...
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218062
02/08/09 09:13 PM
02/08/09 09:13 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Would I better off with lockup or without it?
Re: 518 into 70 cuda [Re: DaytonaTurbo] #218063
02/08/09 09:13 PM
02/08/09 09:13 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
I think its the 96 + that have the hard to use shift system, the first ones had 2 pin connectors, those are the ones that are not lock up, and the three pin ones are a lock-up, the one i got outta a 94 3500 van is lock-up i think, i haven't really looked too close becuase its been too cold until today. i think all the 95 and down are electronic OD and lock-up when they have it. I am not 100% on all this but thats what i have read.
Re: 518 into 70 cuda [Re: 84Stepside] #218064
02/08/09 09:37 PM
02/08/09 09:37 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
When I've done it I used lock up trannys...Why not? take advantage of having a loose convertor that with the flip of a switch it locks 100% & in the case of the two conversions I've done it dropped about 200 rpm..It feels like another gear...I'll be the first to tell you don't load it heavy in O/D or with the convertor locked...But than it's not like you'll be towing a 5,000 lb trailer with your E body.... I actually set them up to shift automatically but also installed a toggle thar locks out O/D & L/U..
Re: 518 into 70 cuda [Re: 1_WILD_RT] #218065
02/08/09 09:54 PM
02/08/09 09:54 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Alright ill try for a lockup tranny then. I almost got one from a 91 dodge van that wasnt lockup yesterday.. good thing I didnt get it heh. How else can I tell if its lockup other than if its 3 wire?
Re: 518 into 70 cuda [Re: derekeh] #218066
02/08/09 10:04 PM
02/08/09 10:04 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
PATC trans has the instructions. The 2 pressure switchs are from a 350 turbo trans and are the 3rd gear clucth switch. The run about $6 ea from a trans supply and you can get different ppressures. I went with 50 and 40 psi. The lock up vacuum switch is from an 86 chevy caprice and is the convertor swith. It runs $40 from any parts store. BWD # TCL 11
Re: 518 into 70 cuda [Re: derekeh] #218067
02/08/09 10:05 PM
02/08/09 10:05 PM
ky.
K
kenworth_goose Offline
K
ky.
You want to try to find a non lockup around 90-91. If you go with a non lockup you can put any 727 convertor in it. But not with the lockup trans. You'll also need to swap out the bellhousing with an untrabell for the 727. It's alot of work but well worth it.
Re: 518 into 70 cuda [Re: kenworth_goose] #218068
02/08/09 10:12 PM
02/08/09 10:12 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Why do I need to swap the bellhousing?
Re: 518 into 70 cuda [Re: derekeh] #218069
02/08/09 10:19 PM
02/08/09 10:19 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You don't.That's only for a BB. Here's one thing you will run into. https://board.moparts.org/ubbthreads/show...e=1#Post5008097
Re: 518 into 70 cuda [Re: stumpy] #218070
02/08/09 10:28 PM
02/08/09 10:28 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Still kindly confused though on if I need lock up or not.
Re: 518 into 70 cuda [Re: derekeh] #218071
02/08/09 10:33 PM
02/08/09 10:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Unless you are running a high horse big cam motor use the lock up.With the stock convertor. It works great.
Re: 518 into 70 cuda [Re: stumpy] #218072
02/08/09 10:40 PM
02/08/09 10:40 PM
Kentucky, USA
derekeh Offline OP
derekeh  Offline OP
Kentucky, USA
Its going to be a 340 with possibly magnum heads and a mild street cam... so I wouldnt call it high horsepower heh
Re: 518 into 70 cuda [Re: derekeh] #218073
02/08/09 10:43 PM
02/08/09 10:43 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Mines behind a street driven 408 stroker in the truck in my sig pic..
Re: 518 into 70 cuda [Re: derekeh] #218074
02/08/09 10:45 PM
02/08/09 10:45 PM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i want to use my stock lock-up converter behind the magnum after its warmed up, just gonna have a nice street cam with more gear now that i have the OD
Re: 518 into 70 cuda [Re: 84Stepside] #218075
02/08/09 10:50 PM
02/08/09 10:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That's the great thing about the swap. I can go to a 3.73 gear for racing and end up with a 2.56 in od. Just shut the od off and go racing. With a 3.91 you end up with 2.75 od.
