.23 shim pack looks right on the money. What if you take out some of the .008-.009?
You mean reduce the backlash from .009?
Thinking of taking the car to The Valley this weekend to see if it breaks into the 12's. Sunday is looking to be 53F and its one of the last days the track is open. Not the best conditions but running out of options this late in the year.
Put some miles on it this weekend, noise no better, no worse. Fixed an oil and power steering leak. Have some AFB tuning to do, slight off idle stumble when light on the pedal. Emulsion tube needs to be drilled out a touch more. Cruise is perfect, WOT needs a little taken out of it. Nice driving around with the wide-band.
At the moment I'm considering Richmond 3.90's but that will have to wait till sometime this winter.
Gary
