Re: Real world weight loss program and it` cost..........
[Re: fullmetaljacket]
#2182918
10/26/16 12:31 PM
10/26/16 12:31 PM
Posts: 1,033 Madison, Wisconsin
chrisnben
Madison, Wisconsin
By the way, being that we are talking about Braile batteries and such. I shaved 3 Lbs just with an aluminum strand main battery cable all the way from the firewall to the rear. It does connect at a junction box at the firewall and a copper cable from there on to the starter. Clean, tight grounds are a must. I have five slim grounds throughout the car. Sounds like a plan for me too. Currently, I have the Braille up front running to the cut-off switch by the shifter (morse cable to rear push/pull). That aluminum cable could be the ticket to put the battery in the rear and take the 21# off the nose. While researching batteries, I yanked the previous owners wiring slop out from the rear mounted, get this- (2) marine batteries at 70# each! I weighed the 2 ga. wire running up to the front at 8.5 #. I'd assume the aluminum wire would be about half of that? Yes sir, you must have ground buss-bars along the entire route as well.
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
[Re: moparx]
#2183232
10/26/16 08:24 PM
10/26/16 08:24 PM
fullmetaljacket
ParX Believe it or not, what you see is an optical illusion. It is simply one side of a polyurethane rear shackle bushing sitting right side up on a bed of two wide rubber washers that one can find at any good True Value hardware store. They are usually found in those multi plastic bin farms that have every screw,bolt and rubber items on the planet. If not, Mcmasters should have 'em.
[Re: chrisnben]
#2183343
10/26/16 10:40 PM
10/26/16 10:40 PM
fullmetaljacket
Here's the Accel lightning cable. Shaved 3-1/2 Lbs off. Previous copper cable at more or less 18'-20' ft was 6 Lbs.
#2190812
11/06/16 05:31 PM
11/06/16 05:31 PM
fullmetaljacket
Clams
#2190813
11/06/16 05:32 PM
11/06/16 05:32 PM
fullmetaljacket
muscles.
[Re: dvw]
#2190996
11/06/16 10:27 PM
11/06/16 10:27 PM
fullmetaljacket
Doug. You suspected them first. The weight reduction is rather inviting as you can see. 50 Lbs shaving just on the shells compared. Trust me, I'm looking very closely at aluminum vent wing channels. Quite difficult without the time and materials.
The very extreme rare items which I've only seen once many years ago are the inner window crank mechanisms in the light alloy. For that, I made a few concessions and made some rather new editions that function great. I'll post some pictures of the inner guts of my current steel doors to show the set up.
#2195701
11/13/16 01:48 PM
11/13/16 01:48 PM
Thumperdart
State of confusion
Wow. Who within us remembers "The Million Dollar movie"?
Now if Thumper could only have a Dollar for each...... he probably would built his own Street race haunt at sea level and have it open to everyone ala the late great Big Willie. RIP
Gee, I'd buy stamping machines to stamp out parts out of aluminum and effectively take the weight off the worlds shoulders.
Carry on. LOL. Whoda thunk.............Way cool to hit a million but WAY cooler for the wealth of knowledge..........thankxx all........
[Re: Thumperdart]
#2195717
11/13/16 02:11 PM
11/13/16 02:11 PM
fullmetaljacket
#2195724
11/13/16 02:24 PM
11/13/16 02:24 PM
Posts: 4,715 Wichita
GY3
Wichita
So here goes for GY3, Chrisnben and other early B-body guys as well as anyone with a Post sedan steel door car. Though this procedure that I performed about 20 years back may seem crude and all, it does retain the functionality of the door without compromising the window cranking up and down as well as the lock/unlock latching. After the inner door panels are installed, it all disappears and all that is left is a stock smooth looking door. The stock steel door shell without anything weighs approximately 40 Lbs as indicated in the earlier post. With this being done, I removed close to 4 Lbs. Laughing?? But wait, there is more to this. Very nice! For some reason I have a problem cutting on mine. I'm all about little tricks and lightening components here and there but always hesitant to cut into it. Maybe it stems from seeing the cool lightweight cars cut and pruned until there's nothing left. Deflowering, so to speak. ![sick sick](/ubbthreads/images/graemlins/custom/sick.gif)
[Re: GY3]
#2195748
11/13/16 03:01 PM
11/13/16 03:01 PM
fullmetaljacket
Yes, yes. Understood of course. These steel doors are getting more and more hard to find, let alone in good condition at all. Of course when I did this, I was under the assumption that I would never find a set of lightweight doors, so I went in with scalpel and drill knowing that the car is a lifer with me anyway. I would never want a door car to not function as a door car should, but I was searching and lurking for wins at the haunts and anything goes in that arena. But to your point GY3, you're right. There are hundreds if not thousands of small places within a chassis that can give effectively and safely an ounce or more with good planning. I'm sure a lot of them have been performed and the norm here.
I suspect that there are a few hidden well conceived ideas still out there to be applied. Why? I sometimes discover them by accident on my own car or squint and hiss when I see 'em on a F.A.S.T swindler. LOL.
[Re: Thumperdart]
#2195860
11/13/16 07:11 PM
11/13/16 07:11 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Jenny Craig has crept into my head.I have been on the scale at E/town & Attco so I have a baseline.I will be adding some weight before my diet. "J" bars,engine limiter and 'chute are at the top of the bucket list. I hope to take over 100 lbs off the nose and start taking from wherever I can.Unlike GY3,I will cut whever needed without compromising integrity. I will try to document as I loose,,,,,,,,,
[Re: hemi-itis]
#2195874
11/13/16 07:43 PM
11/13/16 07:43 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Jenny Craig has crept into my head.I have been on the scale at E/town & Attco so I have a baseline.I will be adding some weight before my diet. "J" bars,engine limiter and 'chute are at the top of the bucket list. I hope to take over 100 lbs off the nose and start taking from wherever I can.Unlike GY3,I will cut whever needed without compromising integrity. I will try to document as I loose,,,,,,,,, Geez, you got a tin can, I'm almost 1,000lbs heavier....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
