Re: Who's good at rebuilding hood hinges?
[Re: 68_661charger]
#2177313
10/17/16 10:59 PM
10/17/16 10:59 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
Does anyone know if you send Rick the hinges with the springs attached or without? i sent him mine springs and all he even swapped out my springs for me because i was using the hinges for a air grabber hood that was being adding on to the car i was very impressed with the job and the turn around time. i highly recommend him.
[Re: 68_661charger]
#2177317
10/17/16 11:00 PM
10/17/16 11:00 PM
Challenger 1
Cincinnati, Ohio
Does anyone know if you send Rick the hinges with the springs attached or without? I would say without would be best. Plus you need to take off the spring first anyway to really see if the hinge is that worn, IMO. You know how to take off the spring?
[Re: Challenger 1]
#2177392
10/18/16 12:20 AM
10/18/16 12:20 AM
Posts: 1,521 Land of the Brave, Home of the...
63CandyMatic
Does anyone know if you send Rick the hinges with the springs attached or without? I would say without would be best. Plus you need to take off the spring first anyway to really see if the hinge is that worn, IMO. You know how to take off the spring? Yes sir. Get a slightly too small, weakened and worn set of vice grips, then pull the end of the spring MUCH further than you need to unhook it. Then at the last minute, when you have it stretched out about 2 feet, make sure the spring eye slips out of the vice grips and the entire spring then skips across the shop, bouncing off the hood of your most recently painted car. Simple.
[Re: migsBIG]
#2178994
10/20/16 05:42 AM
10/20/16 05:42 AM
Posts: 2,271 central IL reg Nov 18, 1999
Stroker
I didn't know he did that service. wonder what his turn around time is like? He did a pair for me and it was almost like Papa John's... Seriously, I was honestly surprised how quick I got them back. He did a good job, & they made a heckuva difference. I don't have to push the rear corners of my hood down after closing it, now. These were for a '72 Charger, btw
