Re: Hemi valve adjustment
[Re: cudachas]
#217966
02/08/09 10:19 PM
02/08/09 10:19 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
First off are you sure it is not Header/ exhaust leak? Anyway, there are two methods to set lifters. One that you described, turning the engine and setting the desigated valves and another method that goes something like Set the intake lash when the exhust valve is opening and the exhaust when the intake is closing. Repeat for each cylinder. Hydralic preload should be 1-1 1/2 turns after inital contact with the lifter. Turn the pushrod with you fingers and when it contacts the lifter and gets tension, that is where the turns start.
[Re: cudachas]
#217967
02/08/09 10:31 PM
02/08/09 10:31 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Are these hydraulic or solid lifters? Your post didnt say.
But it seems like you are adjusting them like a chevy engine would need adjustment.
[Re: cudachas]
#217969
02/08/09 11:54 PM
02/08/09 11:54 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I put a 426 crate hemi from chrysler in my 70 cuda. We got if running last weekend but the valves were noisey. I followed the instructions and adjusted the valves by turning the engine 180 and adjusting various valves to zero than adding a turn and a half.Well they were still making noise so I pulled the covers and gave them all another 1/4 turn. Still noisey , so I again pulled the covers and gave them another 1/4 turn,I still have a couple noisey ones. I have all the valves down 2 turns , should I turn them down some more? Anybody ever adjusted a hemi running? I am getting tired of taking the covers on and off so any advice will be appreciated. By the way ,the car sounds great and has super throttle response, I just hope its not eating the cam.Thanks , Charlie.
Should only be 1/2 turn from zero lash. Might have a couple of bum lifters. No chance the cam is failing because this will make them tick. Might not be a bad idea to pull the intake and lifters and check the bottoms. I don't think you can pull them from the head.
[Re: torkrules]
#217972
02/09/09 11:27 PM
02/09/09 11:27 PM
Posts: 4,179 California
mickm
California
i agree. modern lifters are supposed to be 1/2 turn, not 1 1/2. check the docs for comp cams or something, or if you know the manufacturer of the lifters. there are only a few companies making lifters these days that are bought by most cam companies, so it should all be the same.
[Re: cudachas]
#217975
02/10/09 10:07 PM
02/10/09 10:07 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
Thanks for the phone number , I will call them tomorrow when I get home from work.The motor has a 90 day warranty from date of purchase.I bought the motor on 11/04/08 about 96 days ago,story of my life. I will try the 800 number mopar has in the instruction manual that comes with the motor, maybe they have some suggestions. Thanks,Charlie.
whats the date of assembly on the tag on the crate ??
