Re: 8 3/4 housing
[Re: burdar]
#2179261
10/20/16 05:35 PM
10/20/16 05:35 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
The major difference is that the springs mount above the housing on the truck and below the housing on the car...but you did know that didn't you? I don't mean to be a jerk but after you clean the perches off they all look pretty much the same.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: 8 3/4 housing
[Re: burdar]
#2179277
10/20/16 06:29 PM
10/20/16 06:29 PM
Polarapete
Graham, WA
I helped a friend pull a rear end out of a nasty, rusty '56 Plymouth in a You-Pull-It yard in Everett a few years back for his new project '56. I put together the rear end after cleaning it up with new bearings, seals and brakes. It accepted a 8.75" third member and should bolt into his '56. I think the housing was actually for the Mopar drop out that preceded the 8.75". I don't claim to be an expert on that stuff as most of my experience is with the Dana 60s.
Re: 8 3/4 housing
[Re: burdar]
#2179286
10/20/16 06:51 PM
10/20/16 06:51 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some of the early rear ends that accept a drop-out third member were actually 8 1/4", not 8 3/4". Count the fasteners that hold the third member, the 8 3/4" has 10 and the 8 1/4" has 11.
