440 Heater Hose routing #2179032
10/20/16 10:43 AM
10/20/16 10:43 AM
FLPlum Offline OP
FLPlum  Offline OP
Hello,
Need help with the heater hose routing on my 1970 Challenger, 440 with a/c.
Can someone show me the original correct routing and bracket, that should be on my engine.
Specifically where the hoses route above the alternator.
It is an early build car, if that makes a difference.
Also, what the original hoses should be marked, as well.
Thank you for your help.
Mike
Re: 440 Heater Hose routing [Re: FLPlum] #2179169
10/20/16 02:42 PM
10/20/16 02:42 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Do you have a service manual? It will show you the routing. If you are wanting date coded hoses, then Frank Badalson has them.
