Page 3 of 3 1 2 3
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180507
10/22/16 08:26 PM
10/22/16 08:26 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Without compound... .026 shim pack
"I think its got a hemi"
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180511
10/22/16 08:30 PM
10/22/16 08:30 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
.023 shim pack
Re: Ring and Pinion pattern (round two) [Re: moparts] #2180744
10/23/16 09:24 AM
10/23/16 09:24 AM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
Originally Posted By moparts
US STANDARD GEAR - from what I have heard are over stock or non spec. Yukon GEAR
thanks for the clarification. up
beer
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2180848
10/23/16 01:39 PM
10/23/16 01:39 PM
GA
roadrunninMark Offline
GA
.23 shim pack looks right on the money. What if you take out some of the .008-.009?
Might try this stuff too: Red Line 58204 Heavy ShockProof Gear Oil
Re: Ring and Pinion pattern (round two) [Re: roadrunninMark] #2181248
10/24/16 06:54 AM
10/24/16 06:54 AM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
You mean reduce the backlash from .009?
Thinking of taking the car to The Valley this weekend to see if it breaks into the 12's. Sunday is looking to be 53F and its one of the last days the track is open. Not the best conditions but running out of options this late in the year.
Put some miles on it this weekend, noise no better, no worse. Fixed an oil and power steering leak. Have some AFB tuning to do, slight off idle stumble when light on the pedal. Emulsion tube needs to be drilled out a touch more. Cruise is perfect, WOT needs a little taken out of it. Nice driving around with the wide-band.
At the moment I'm considering Richmond 3.90's but that will have to wait till sometime this winter.
Gary
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2181442
10/24/16 01:29 PM
10/24/16 01:29 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I installed a motive set in my brothers 9" ford a while back. I remember the sheet of paper that came with them called for more backlash than the original factory service manual did. I was sort of reluctant to do that , but did. So far so good with it. Might be worth looking into, wish you the best. Every set up I have ever done I have only take apart 20-30 times to try to get it the best I can. Way to much OCD for me to do that for a living! LOL
Matt
Re: Ring and Pinion pattern (round two) [Re: gdonovan] #2181517
10/24/16 02:58 PM
10/24/16 02:58 PM
Oakdale CT
gdonovan Offline OP
gdonovan  Offline OP
Oakdale CT
Backlash set to loose side of Motive sheet. Factory is 005-008
Page 3 of 3 1 2 3
