Rod knock or Cracked Flexplate or ?? **UPDATED**
#2177019
10/17/16 03:24 PM
10/17/16 03:24 PM
Posts: 182 USA
Nitrofish
USA
Hello, Looking for some opinions on a noise that 496 BB is making. It has never been a mechanically quiet engine. However, this noise is currently not present on a cold engine at any rpm. At least to my ear. However, once the engine is hot it is audible. No power loss is present. Not very noticable at idle. Most noticeable at a constant engine speed of 2,000-3,000 rpm. Also on deceleration of engine rpms. The noise is present in Park or in Gear, no real change to the noise. Noticed this after a weekend at the drag strip making quite a few passes. Engine oil level is correct. Pressure is 30-40 psi at idle depending on temperature. Oil pressure raises quickly with rpms. Recently changed to Joe Gibbs Driven 10w40 oil about 1 month ago from Lucas Hot Rod oil 20W50. I have not drained the engine oil for inspection just yet. No change to the concern removing one spark plug wire at time. 496BB Hydraulic Flat tappet .540 lift Dur @ .050 251 Int & 263 Exh Eagle Crank and Eagle H-Beam rods Indy SR Aluminum Heads Timing is set at 34* 727 3800 Turbo ACtion coverter, B&M flexplate https://www.youtube.com/watch?v=DrtTynp6pHwhttps://www.youtube.com/watch?v=zrRS5MOOk48https://www.youtube.com/watch?v=xDldGUt3lbAPlease see video descriptions Thanks!
Re: Rod knock or Cracked Flexplate or ??
[Re: Nitrofish]
#2177033
10/17/16 03:47 PM
10/17/16 03:47 PM
Posts: 13,530 Marion, South Carolina [><]
an8sec70cuda
I'd check the converter bolts first. If those are tight, I'd pull the valve covers and look for a loose rocker and/or lash opening up.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Nitrofish]
#2178452
10/19/16 09:35 AM
10/19/16 09:35 AM
Posts: 75,324 A gulag near you.
JohnRR
A gulag near you.
Who installed the cam bearings and who installed the cam ?
I doubt you have anywhere near enough spring pressure to have the cam move around enough to do that . Mopar cam tunnels are notoriously tight and out of round on seasoned blocks, if the cam bearings weren't clearanced for the cam that was going to be run when the engine was built then it clearanced itself once it was run.
What do you cam lobes look like ?
Mainstream Media is the new Pravda
[Re: Nitrofish]
#2178525
10/19/16 12:15 PM
10/19/16 12:15 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Those pictures don't strike me as "wear", that looks more like damage that could have only occurred at time of install to me. It also doesn't seem like the sort of thing that would cause the noise I heard in the earlier videos.
Do you run a mechanical fuel pump? If so, you might look at the pushrods and arm. Just a thought.....
[Re: Nitrofish]
#2178603
10/19/16 01:54 PM
10/19/16 01:54 PM
Posts: 43,882 Bend,OR USA
Cab_Burge
One of the machine shops I use to use in Orange County, CA would hone out the out of round and undersize cam journals in my blocks to factory size. I had ask him about align honing them and he said he couldn't do to them all being different I.D. I ended up buying the tool set needed to install cam bearings in my shop and I install the rear cam bearing first and slide the cam in, if it rotates freely I repeat until all five of them are in. I have had more than block that the new cam bearing wouldn't allow the cam to spin properly do to being to tight and I had to scrape those bearings with a bearing knife repeatedly removing the high spots until it rotates freely It sounds like your block is one of those needing custom fitted bearings or fixing the block cam journal I.D. : Let us know what you find this time and decide to do to fix it
[Re: Nitrofish]
#2178649
10/19/16 03:01 PM
10/19/16 03:01 PM
JohnRR
A gulag near you.
I also thought of the fuel pump pushrod and arm. It is certainly worth an inspection.
However, I dont think there is much material left on the cam bearings. Therefore, I still need to correct this issue.
Thanks for the response. I'm open to any other thoughts or advice. There is a lot more bearing material on that cam bearing insert than you think, I doubt that is the source of the noise. You could pull the engine and go thru it and change the cam bearings if it will make you feel better.
[Re: Nitrofish]
#2178671
10/19/16 04:27 PM
10/19/16 04:27 PM
Posts: 1,324 Ohio
jlatessa
Ohio
Not to hack this thread, but I'm going though the same elimination route for my knock.
Plug wire pulling told me nothing too, checked fuel pump push rod...OK Absolutely NO type of residue after pulling valve covers and in the drain pan when I last changed the oil three weeks ago.
Oil pressure 80 cold, 35 hot with 10/30 VR1, rods and mains were at both at .0025 when buttoned up last year.
Hydraulic FT purple cam, Hughs roller rockers, six pack, Hooker Super Comps.
I guess I'll put the car up and take a peek at the converter bolts.
Pulled all the plugs and they all look rich (idle) noticed oil pooled near a rear intake bolt (above #6) That plug shows a lot of soot. Time to pull manifold and use some additional sealing. Be able to look at the lobes too.
I'll chime in if I find anything else.
Good luck Nitrofish, Joe
PS I agree that the marks I see on your cam bearings look like an unorthodox installation.
