Max wedge cam advice #2176648
10/17/16 03:36 AM
10/17/16 03:36 AM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
Looking for a little help selecting a new cam.
Heres what I've got.
62 Dart
426 max wedge 12.5:1 comp
Stage 3 heads and stock crossram/3705 carbs
3600lb car, with an auto (J converter) and 4.30 gears.
Right now the car has a MP .533 hydraulic P4529318. From what I gather, its not very well liked...
This setup ran 12.00's at sea level, but up here at 6000ft elevation, I'd like to see if I can squeeze a little more out of the car.
Leaning towards a solid cam this time, but am open to suggestions.
Re: Max wedge cam advice [Re: GPSflyer] #2176651
10/17/16 03:48 AM
10/17/16 03:48 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Im no cam Guru but we just put this solid cam in a 440 11.5-1 with indy heads and 1.6 rocker, it hauls ass . Someone smarter than me will chime in.
All the best.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Max wedge cam advice [Re: GPSflyer] #2176653
10/17/16 03:51 AM
10/17/16 03:51 AM
Cab_Burge Online work
Cab_Burge  Online Work
I've owned and raced a lot of different M.W. motors and cars over the years at variuos altitudes,NHRA stock to S/G, none above 5500 Ft elevation though. I would look at a solid lifter or solid roller lifter cam that had between 250 to 270 degrees duration at .050 lifter rise and as much lift as you can get up Have it ground on 106 to 110 lobe seperation angle, more duration wider LSA, and install it with between 3 to 6 degrees advance on the intake lobes.
I use to use a lot of Isky cams, my favoriite solid lifter grind is not in thier catalog anymore, it was thier old .590/616(EDITED) grind, they would probally make you one as a custom grind now. It was ground on a 104 LSA and it had a bunch of bottom end and would usually quit pulling hard around 7000 RPM with the bigger Stage 3 heads, intake and carbs like you have upIHTHs
There are a lot better cams out there now, I like and use Comp Cams and Bullet Cams for most of my builds now starting back around twenty yrs agoluck
Re: Max wedge cam advice [Re: Cab_Burge] #2176655
10/17/16 03:59 AM
10/17/16 03:59 AM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
Excellent info, Thanks!
Re: Max wedge cam advice [Re: GPSflyer] #2176681
10/17/16 08:20 AM
10/17/16 08:20 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you know what your valve to piston is,if that will limit you in any way?A roller would be nice if in the budget.What rpm do you want to go to?How are the rods?What rpm are you doing in the traps now?
Re: Max wedge cam advice [Re: GPSflyer] #2176683
10/17/16 08:24 AM
10/17/16 08:24 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do you have the room on the valve guides for more lift like a .590 or .620 lift?
Re: Max wedge cam advice [Re: Clanton] #2176689
10/17/16 08:54 AM
10/17/16 08:54 AM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
I don't know how much clearance I've got. I'll have to pull a couple springs and find out. This engine did have a MP .590 in it years ago. I'm guessing there has to be something a little more modern available now?
Its got good rods, and crane gold rockers.
RPM? Can't remember, lol, the car has been hibernating for years. I don't think the car has been down the track since 2001-ish.
Re: Max wedge cam advice [Re: GPSflyer] #2176696
10/17/16 09:22 AM
10/17/16 09:22 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Sounds like you will be able to do better.
Re: Max wedge cam advice [Re: GPSflyer] #2176787
10/17/16 12:30 PM
10/17/16 12:30 PM
AndyF Offline
AndyF  Offline
Really depends on how the car is going to be driven. Are you going to be racing it only or driving on the street? If it is a drag race only car with open headers then you can go ahead and put something a little ratty in there but if you are going to be driving it on the street I'd stay with something fairly mild.
Re: Max wedge cam advice [Re: GPSflyer] #2176879
10/17/16 02:02 PM
10/17/16 02:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
At 12.5 cr I think it is a drag car is safe to say.
Re: Max wedge cam advice [Re: GPSflyer] #2177018
10/17/16 04:23 PM
10/17/16 04:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd suggest a fast rate solid cam that doesn't have lots of duration.
Lsa somewhat dependant on the exhaust system being used for track use.
Re: Max wedge cam advice [Re: GPSflyer] #2177066
10/17/16 05:36 PM
10/17/16 05:36 PM
AndyF Offline
AndyF  Offline
I have a few cams on the shelf that might work. A Racer Brown STX-19M which is 257 duration and .527 lift. Or a Comp XTQ/XTX cam that is 252/258 with .540/.539 lift. Or a Scott Brown custom which is 248/258 with .563/.555 lift. The lobes on the Scotty Brown cam are pretty aggressive.
Re: Max wedge cam advice [Re: GPSflyer] #2177079
10/17/16 05:58 PM
10/17/16 05:58 PM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
Thanks guys.
Yeah, it's not really going to see a ton of street miles, so friendliness isn't much of a concern. With the cost of good gas, I keep the trips short. lol
Oh, and the car has 2" primary headers on it, not max wedge exhaust manifolds.
Re: Max wedge cam advice [Re: GPSflyer] #2177164
10/17/16 07:39 PM
10/17/16 07:39 PM
So. Burlington, Vt.
So. Burlington, Vt.
Are they 286 or 518 heads?
Ported or not?
2.08 intake valve?
Car is raced with headers open or closed?
If closed, what's the exhaust system from the headers back?
Re: Max wedge cam advice [Re: fast68plymouth] #2177189
10/17/16 08:13 PM
10/17/16 08:13 PM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
518, unported.
2.08 1.88 valves
It's got max wedge style exhaust dumps on the headers. Opened up at the track.
Re: Max wedge cam advice [Re: GPSflyer] #2177325
10/17/16 11:04 PM
10/17/16 11:04 PM
Canada
Max Weg Offline
Max Weg  Offline
Canada
watch how much lift you have as anything over .600 get hard to fit the exhaust valve in the cylinder. if your a 4.350" or bigger bore you should be ok.
Max Weg
Re: Max wedge cam advice [Re: GPSflyer] #2177359
10/17/16 11:38 PM
10/17/16 11:38 PM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
It's a 4.25" bore, so I might not be able to go crazy on the lift.
Re: Max wedge cam advice [Re: GPSflyer] #2177362
10/17/16 11:38 PM
10/17/16 11:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Do your heads flow much above .550 lift?You may get results from more lift sooner like .100 more by .250/.300 lift from what you have,IDK if other than a roller can do that.
Re: Max wedge cam advice [Re: GPSflyer] #2177378
10/17/16 11:55 PM
10/17/16 11:55 PM
Is your block a 426 street wedge or race wedge block? If it is a race block it will have the exhaust valve reliefs already cut in the cylinder walls so the max lift shouldn't be a real problem with most solid lifter race cams. That is one of the things that always need checking when changing cams just like valve to piston clearances scope I have cut those exhaust valve reliefs in 426 Street Wedge blocks also for max wedge heads and valve to block clearances thumbs
Re: Max wedge cam advice [Re: Cab_Burge] #2177414
10/18/16 12:39 AM
10/18/16 12:39 AM
Colorado
GPSflyer Offline OP
GPSflyer  Offline OP
Colorado
It does already have the reliefs cut in the top of the bores.
