Throttle cable #2120682
07/29/16 03:30 PM
07/29/16 03:30 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
I believe I have an incorrect throttle cable on my 68 Dart GTS 340. Can anyone tell me that the length should be from the firewall forward?
Re: Throttle cable [Re: GKMOPAR] #2121104
07/30/16 03:30 AM
07/30/16 03:30 AM
I dont have a dimention but is there too much slack in the section between the throttle clamp and the firewall?
Re: Throttle cable [Re: GKMOPAR] #2121129
07/30/16 09:03 AM
07/30/16 09:03 AM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
Yes it is looped to make it work. Looks like the distance between the bracket and carb in too long because it is barely in the clamp. I checked on the bracket and it is correct.
Re: Throttle cable [Re: GKMOPAR] #2121154
07/30/16 10:14 AM
07/30/16 10:14 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
If it's looped, you have a slant six cable, they are the longest.
The one Classic Ind lists for a 340 A body is 19" long.
http://www.classicindustries.com/product/mopar/parts/mn2227.html
Re: Throttle cable [Re: GKMOPAR] #2121415
07/30/16 05:32 PM
07/30/16 05:32 PM
Hilliard, Ohio
GKMOPAR Offline OP
GKMOPAR  Offline OP
Hilliard, Ohio
That's what I need to know. Thanks for the info. Looks like the one @ Classic industries is on backorder. Will try to locate a nice used one or try another supplier.
Re: Throttle cable [Re: GKMOPAR] #2175563
10/15/16 11:36 PM
10/15/16 11:36 PM
FL
70stroker Offline
70stroker  Offline
FL
Nice list from Mancini Racing.
