Re: Carb Spacers
[Re: PS Arrow]
#217529
02/08/09 09:58 AM
02/08/09 09:58 AM
Posts: 1,532 off the grid
340B5
off the grid
Cab, or anyone else. Has anyone ever tested Tapered Spacers, such as the Wilson or HVH, and what situations/configurations do they work best in?
Yeah, it's got a smallblock.
Re: Carb Spacers
[Re: PS Arrow]
#217530
02/08/09 10:21 AM
02/08/09 10:21 AM
Posts: 5,067 Orlando Florida
blown572dart
Orlando Florida
How soon???? Inquiring minds want to know....
Here is some info: The wheel base is going to be around 118" and the car should be a little lighter.It will have a 6.00 cert .
I hope to have it at SGMP in May but there is alot of work to do.
![](/ubbthreads/images/graemlins/popcrn.gif)
Re: Carb Spacers
[Re: PS Arrow]
#217531
02/08/09 11:08 AM
02/08/09 11:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I was looking at the the Wilson Manifold web site for a carb spacer, I dont know the advantages or disadvantages of running a 4 hole spacer versus an open, My manifold is an M1 Dominator single plane. What would be my best choice? Thanks
Its not quite as cut and dry as this works and this doesnt.... if you need the volosity for the carb a 4 hole works better... but if you are looking for more plenum the open spacer works better. The intake itself that you are using makes a difference... but on almost all intakes a spacer helps with the exception of tunnel rams(and all that does is move things in the rpm range). ![](/ubbthreads/images/graemlins/wave.gif)
Re: Carb Spacers
[Re: PS Arrow]
#217532
02/08/09 02:07 PM
02/08/09 02:07 PM
Posts: 43,332 Bend,OR USA
Cab_Burge
Cab, what is a reversion spacer, how does it work? Is it a 4 hole?
There are two version of thr reversion spaces that I know of, the one that Wilson makes like in my picture( there part #024130) and a thinner two piece version that Rehr and Morrison sells. How they work is beyond me other than blocking reversion into the carb, I think They both work as I have seen, heard and tested the results on motors on engine dynos ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Carb Spacers
[Re: Georg]
#217534
02/09/09 10:55 AM
02/09/09 10:55 AM
Posts: 411 Big Island ,VA
JC Childress
Big Island ,VA
anyone ever used the Wilson spacer for a Thermoquad carb that moves the carb forward about .300 ?
J.C. Childress
(434) 665-9541
