Page 60 of 82 1 2 58 59 60 61 62 81 82
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2193438
11/09/16 07:55 PM
11/09/16 07:55 PM
Ontario, Canada
RealWing Offline
RealWing  Offline
Ontario, Canada
If I could get into the web site, I'd find the phone number to call him!! I simply wanted to confirm which of the 2 plugs on the bottom of the tranny is the drain plug. Does anyone Know??
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2193440
11/09/16 07:58 PM
11/09/16 07:58 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
There should be a d on the drain plug
"It takes a Mopar to catch a Mopar”
1970 Challenger T/A 4 speed EV2
Re: New Passon Performance 5 Speed update [Re: MoparJunkie] #2193750
11/10/16 08:05 AM
11/10/16 08:05 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Website must bevgetting work done
Im sure if you googled a little you would find -
Cant believe noone would post the tel number
its not secret
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2200690
11/22/16 05:47 PM
11/22/16 05:47 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I have no hope of getting one of these trans, so I'm seriously looking into this:
https://shiftsst.com/articles/cat/mopar/post/challenger-barracuda-1970-1974-perfectfit-kit/
Tremec T56 Magnum Kit Components
Tremec T56 Magnum 6 Speed Double Overdrive
PerfectFit Shifter position fits inside the factory console
700 torque capacity wide or close ratio.
Friction Lined Synchronizer Blocker Rings come standard for easy high RPM shifts
Full 12 month warranty with unlimited technical support, 24 month installation window
Optional Add the Front Shift Kit for bench seat clearance
SFI Rated Steel Bellhousing
Hydraulic Clutch Actuator Kit
6-Speed Pattern Shift Handle Insert
Sheetmetal to widen tunnel
Speedometer Connection
Mechanical and electronic compatible
Speedo Gear
Reverse Light Connector
Pilot Bearing
Super heavy duty needle roller type with lube seal for long life
Crossmember - No need to replace torsion bar suspension. Stronger than the original equipment crossmember.
Isolator Mount
Rubber for vibration isolation
Installation Hardware
Slip Yoke and Driveshaft
Detailed Installation Instructions - including free lifetime tech support
12 Month Product Warranty
Includes 24 month activation delay so you can finish your project.
Re: New Passon Performance 5 Speed update [Re: 2fast4yourBrain] #2200843
11/22/16 09:58 PM
11/22/16 09:58 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
http://americanpowertrain.com/i-23887154...-speed-kit.html
Here is a new 6 speed kit from American PowerTrain which looks different from the generic one they sold me 2 years ago.
It looks pretty complete just add your Quicktime bellhousing for Big block or smallblock/Gen III. For automatic swaps they sell the clutch pedal conversion as well. Hopefully they fixed their White Lightning shifter as the early versions were crap and leaked constantly.
American Powertrain also has pretty good customer service. As always there were a few issues in any custom install but I was was happy to deal with them.
No reason why to wait around now, The T56 Magnum is a proven transmission. Thousands of miles, track days and mine has never skipped a beat. If I ever do break it, I simply make a call, fork over 3 grand and get another one in matter of days.
You are not getting any younger fellas!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2202223
11/25/16 03:35 AM
11/25/16 03:35 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I have the same in my Dart.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2202410
11/25/16 03:13 PM
11/25/16 03:13 PM
Colorado
Slimfish Offline
Slimfish  Offline
Colorado
We put one of those in a friends Fury just about a year ago because he gave up on waiting for the Passon tranny. It seems to be working well. The tunnel mod was the biggest issue. Looks like this is becoming the only option for the foreseeable future.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2203145
11/27/16 01:42 AM
11/27/16 01:42 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Tremec t56 magnum. Is that not the same tranny in a hellcat?
If so. That's a bad ass tranny. Iv beat the crap out of the one in our cat
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2203184
11/27/16 02:27 AM
11/27/16 02:27 AM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Sounds like both AMT and SST have 6-speed kits for e-bodies.
At least the VERY hard part they figured out:
- crossmember
- shifter placement.
STill gotta hack the tunnel. Not that big a deal I don't think.
I wonder if the torsion bar x-member will need whacking???
Re: New Passon Performance 5 Speed update [Re: 2fast4yourBrain] #2203306
11/27/16 01:10 PM
11/27/16 01:10 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I've held off on replying to this thread for a while now. I've been on the list since 2011. I am supposed to be 88 or 89 I don't remember now. I have not received any calls, emails, nothing. I'm heavily leaning towards possibly a 6 speed or at least a TKO 5 speed because of this.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2203380
11/27/16 03:52 PM
11/27/16 03:52 PM
NotRussia
2
Whack top Dodger
Whack top Dodger
2
NotRussia
Re: New Passon Performance 5 Speed update [Re: 2fast4yourBrain] #2203416
11/27/16 05:05 PM
11/27/16 05:05 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Wow that is pretty cool how they made an offset portion to make it fit into the stock location and console of original 4 speed cars!
I personally would not like all the extra parts and wonder how it would change the shift feel compared to direct into the trans?
It seems like these companies really did some research in order to make things more affordable as I had to pay a bunch of custom work in order to make my T56 Magnum fit properly
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: New Passon Performance 5 Speed update [Re: rck850] #2203758
11/28/16 02:50 AM
11/28/16 02:50 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
So your saying that you have been on the list for 5 years and was only #89. And still don't have a tranny??
That's just crazy
1971 charger
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2204859
11/29/16 11:15 PM
11/29/16 11:15 PM
Long Island, NY
mjb765 Offline
mjb765  Offline
Long Island, NY
I am somewhere in the 170's I think.....Jamie told me last week it should be a year or less.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2205162
11/30/16 11:17 AM
11/30/16 11:17 AM
Colorado
Slimfish Offline
Slimfish  Offline
Colorado
I talked to a friend in our club who claims he's in the low 40s on the list. He's still waiting for notification. But, he did add that his car is an A-body.
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2205173
11/30/16 11:35 AM
11/30/16 11:35 AM
MoparJunkie Offline
MoparJunkie  Offline
Like I stated earlier, the numerical number doesn't mean that's the order you're getting a trans....
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2213224
12/13/16 10:38 AM
12/13/16 10:38 AM
Colorado
Slimfish Offline
Slimfish  Offline
Colorado
Has anybody on the board received a transmission since mid October?
Re: New Passon Performance 5 Speed update [Re: Slimfish] #2213374
12/13/16 03:22 PM
12/13/16 03:22 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
I received my 2 trans at the end of october,I was # 30 on the list....
Re: New Passon Performance 5 Speed update [Re: ogopogo] #2213389
12/13/16 03:51 PM
12/13/16 03:51 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
I'm getting ready to pick up the one for my A body right after the holidays.....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: New Passon Performance 5 Speed update [Re: JamiePasson] #2213505
12/13/16 07:34 PM
12/13/16 07:34 PM
Colorado
Slimfish Offline
Slimfish  Offline
Colorado
Awesome! It's good to know that some are actually getting into the hands of customers. Makes my decision hard....should I stay or should I go now.....
