Re: thread sealer on pick up tube? [Re: BSB67] #2174393
10/14/16 09:40 AM
10/14/16 09:40 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Its called NPT national pipe thread taper. It is designed to have an interference fit. If it didnt you would bottom out the threads when it was tightened. I have been in engineering for over 35 years. I have seen many motors where there is pipe dope or teflon stuck in the oil pump!!
https://en.wikipedia.org/wiki/National_pipe_thread
Re: thread sealer on pick up tube? [Re: mopar dave] #2174396
10/14/16 09:51 AM
10/14/16 09:51 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
ok, I have lock tite thread sealer, gasket shellac as well as blue lock tite on the shelf. looks like I'm good.
Re: thread sealer on pick up tube? [Re: R/T1968R/T] #2174442
10/14/16 11:54 AM
10/14/16 11:54 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
That's because the donkey that put it on there put too much on and went right to the end of the threads.
Re: thread sealer on pick up tube? [Re: mopar dave] #2174452
10/14/16 12:14 PM
10/14/16 12:14 PM
Az
Crizila Offline
Crizila  Offline
Az
I use red Loctite.
Fastest 300
Re: thread sealer on pick up tube? [Re: dogdays] #2174742
10/14/16 06:41 PM
10/14/16 06:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By dogdays
NOT All pipe threads are tapered. There is a standard for straight pipe threads, NPS. I believe the oil pickup tube is NPS.
Correct, the factory tubes and the MP replacements are straight pipe thread (measure it for yourself) but the block threads are tapered so there is enough interference fit to allow the pipe to tighten without using a jam nut.
Since a NPT combo is often known to leak, a straight/tapered combo is likely to leak also so a sealer seems prudent.
Re: thread sealer on pick up tube? [Re: John_Kunkel] #2174776
10/14/16 07:53 PM
10/14/16 07:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I suspect that the reason that did the straight into taper is to allow greater adjust-ability at getting the PU in the right orientation without busting the block. You can see that only the first two or so threads are wedged into the thread root in the block.
Re: thread sealer on pick up tube? [Re: John_Kunkel] #2174777
10/14/16 07:54 PM
10/14/16 07:54 PM
Cab_Burge Online work
Cab_Burge  Online Work
I learned something new today shock whistling
Re: thread sealer on pick up tube? [Re: Cab_Burge] #2174782
10/14/16 08:00 PM
10/14/16 08:00 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I use to get flamed for stating this in past posts. I guess people finally pulled out their calipers.
Re: thread sealer on pick up tube? [Re: BSB67] #2174793
10/14/16 08:16 PM
10/14/16 08:16 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I think some of you are a little confused, look at the definition of NPT. The taper is actually in the thread angle itself. Its not that the pipe (or hole) gets smaller on the end.The different thread angle is what causes the interference. This would agree with what john said above.
This is from the engineering tool box website.
the angle between the taper and the center axis of the pipe is 1o 47' 24'' (1.7899o)
truncation of roots and crests are flat
60o thread angle
pitch is measured in threads per inch
Re: thread sealer on pick up tube? [Re: R/T1968R/T] #2175001
10/15/16 01:48 AM
10/15/16 01:48 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I'm not confused at all.
Re: thread sealer on pick up tube? [Re: mopar dave] #2175037
10/15/16 02:44 AM
10/15/16 02:44 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I use red loctite too. Maybe it's not needed, but it has never caused a problem for me.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: thread sealer on pick up tube? [Re: Hemi_Joel] #2175139
10/15/16 11:10 AM
10/15/16 11:10 AM
Mt Morris Michigan
Mt Morris Michigan
I'm leaning towards the blue loc tite.
Re: thread sealer on pick up tube? [Re: R/T1968R/T] #2175153
10/15/16 11:31 AM
10/15/16 11:31 AM
moparx Offline
moparx  Offline
60o thread angle
the above statement[s] are true. however, for example, a 1/4-18npt thread can be taped using a 7/16" drill for a through hole and get acceptable results. but you will get superior results using a 27/64" drill and a 1/4npt TAPERED reamer, which as the description implies, DOES make a tapered hole. this method is better because it can be used with or without sealer, and assists the 60* thread angle in doing it's job as designed. the practice of using straight through holes was started as a cost saving manufacturing move when it was discovered acceptable [usable] results could be obtained using a non tapered hole for most applications requiring pipe threads. in the above example, the 7/16" drill size is also the required size for a 1/4-18nps[coupling] thread, allowing use of just a common drill without a reamer operation for both types of pipe threads. i also own several common sizes of taper gages used to ensure the proper hole TAPER is obtained before tapping a tapered pipe thread. these gages have a very pronounced [obvious] taper that can be easily seen by the eye. i used this method daily for 42+ years as a machinist tapping 1/8 through 4"npt threads in natural gas metering devices. upon the advent of cnc machining, the tapered reamer was made obsolete in the smaller [1" or less] sizes as it was very easy to bore a tapered hole of the required dimension needed for the larger sizes, and this hole taper was a mandated check for quality purposes.
beer
Re: thread sealer on pick up tube? [Re: moparx] #2175472
10/15/16 09:25 PM
10/15/16 09:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
60o thread angle
beer
and if you show one of the younger CNC machinist today a tapered pipe reamer, they look at you and ask what the heck is that for and I tell them back when I was younger doing aerospace machining that was the only acceptable way to thread tapered pipe threads, especially in cast iron and as far as thread sealer,,never seen a plumber yet that didn't use it.
