Indy 360-1 heads + TTI headers
#2174819
10/14/16 09:17 PM
10/14/16 09:17 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I am considering going with a set of TTI W2 headers for my 408 small block with Indy 360-1 heads, I now have an old set of worn Tubular Automotive headers that need replaced. Do any of you guys have any experience with them? how do they fit ? easy installation? do I still need a 90 degree adapter? how do the fit with a Moroso pan? Thanks
Re: Indy 360-1 heads + TTI headers
[Re: 11secdart]
#2174946
10/14/16 11:58 PM
10/14/16 11:58 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I had the tubular ones on my car and switched to tti and wow tti is such a nicer fitting header. You will like them a lot better. I had Indy heads in my 67 a body.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 11secdart]
#2174963
10/15/16 12:22 AM
10/15/16 12:22 AM
Posts: 8,046 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Good fit. You will have to cut one of the bolt loops off that protrude under the exhaust port on drivers side. Header will not go on without removing that unless they have changed the header design.
[Re: 11secdart]
#2174998
10/15/16 01:43 AM
10/15/16 01:43 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
I run them on my Dart. As Mopar Dave said 1 extra head bolt boss is in the way some. I ground it down so it would clear. If the engine is out bolt the headers up and you will see whats up.
Don't buy the w2 headers get the headers for 360-1(port shape is different)I suggest you call TTI, then place your order from who ever with good information.
"Just a Bracket car dressed up like a streetcar"
[Re: SpareParts]
#2175123
10/15/16 10:42 AM
10/15/16 10:42 AM
11secdart
new jersey usa
Thanks for the great response guys, I only have one more race for the season tomorrow and then the header installation will be a winter project. I had to dent one of the Tubular Automotive tubes to clear one of the bosses on the passenger side also. I don`t think they fit the Indy heads very well as I am always replacing gaskets. One advantage I see so far is no more 90 degree adapter which is another source for leaks and adapter plates. It looks like the TTIs are the way to go. What do you have Spare parts? Thanks
[Re: 11secdart]
#2175539
10/15/16 11:03 PM
10/15/16 11:03 PM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
I have found the TTI W2 headers install just fine as long as you follow the instructions for locating the engine and installing the headers. Also, when they say to jack the car up they mean jack the car up real $%^&*(& high lol.
68 Barracuda Formula S 340
