C clip eliminator's for a 9.25 #217480
02/08/09 01:40 AM
02/08/09 01:40 AM
MN
hemidup Offline OP
hemidup  Offline OP
MN
Anyone make them? Even a custom hookup (link) would be great.
Jerry Williams.
Re: C clip eliminator's for a 9.25 [Re: hemidup] #217481
02/08/09 07:19 AM
02/08/09 07:19 AM
HR3128 Offline
HR3128  Offline
I have been looking for the same thing. None of the usual manufacuters make a kit for the 9.25. I was thinking about making a set but thinking about it is as far as I have gotten. I think the problem is that there are no retained bearings made for the stock axle diameter.
I have heard about replacing the housing ends(Dana/8-3/4 ??) and axles but the info I have found was not very detailed. Dr. Diff(member here) has these parts available. This is probably the best way to go but it dosen't fit my no budget project right now.
Re: C clip eliminator's for a 9.25 [Re: hemidup] #217482
02/08/09 09:32 AM
02/08/09 09:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Why not put these on
link
And then have axle shafts made with 8 3/4 bearing provisions and the length + spline you need.
