Re: Electrical Trouble 1971 Dodge Challenger [Re: sanman68] #2174464
10/14/16 12:29 PM
10/14/16 12:29 PM
Everything is working now but probably will draw down the battery when i get the rest of the car going.
agreed, we cannot have a key off draw. & on the other, Keep in mind that the power and ground sides are seperate & that the blue wire circuit should always be hot with key on no matter if there is a ground side issue (or not). stay in touch, we'll get back after it when the time comes
Re: Electrical Trouble 1971 Dodge Challenger [Re: sanman68] #2176508
10/16/16 11:13 PM
10/16/16 11:13 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Sanman68
Without a ground the voltage will find the path of least resistance to ground which can do strange things.
[/quote]
Exactly. When any electrical issue gets crazy, doesn't make sense and/or seems to affect unrelated things, it's a ground issue. You can count on that 99% of the time.
Re: Electrical Trouble 1971 Dodge Challenger [Re: shorthorse] #2178077
10/18/16 09:09 PM
10/18/16 09:09 PM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
Thanks for the replies I will write more when I know something. It may be a few months.
Sanman68
Re: Electrical Trouble 1971 Dodge Challenger [Re: sanman68] #2178179
10/18/16 10:57 PM
10/18/16 10:57 PM
take your time, we ain't going anywhere
