Re: Trick Flow heads
[Re: fast68plymouth]
#2172970
10/12/16 03:41 PM
10/12/16 03:41 PM
Posts: 31,082 Oregon
AndyF
Since Andy will have both the TF 240 and 270 on hand, maybe if he's looking for something to test, he could do that very test. Swap only the heads and manifold and see just how it shakes out. That is the plan but no guarantee that it will actually happen. It takes a lot of time (and money) to do a back to back head swap on the dyno. I don't think the torque peak would move up a huge amount if the cam and carb stay the same. The torque peak could move up more if the cam is made bigger. At some point the engine might want bigger headers too. I think changing the head cross section by 25% starts a whole domino string.
#2173074
10/12/16 06:54 PM
10/12/16 06:54 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Here's my grey matter 3.2 prediction.....
On a "typical" 493/505/520 bracket or hot street type build, with normal compression ratios(10.0-13.5) and cam lift/duration(.550-.700 lift, 250-280 @.050) running a single plane manifold with a properly sized carb, and the proper sized headers for the application, the TQ peaks would be within 500rpm of each other if you changed ONLY the heads and intake manifold. Dwayne , what potential HP gain would think ? If say swapping out only the heads . Or would you maybe need to pick up some lift , 1.6 rocker change ? thanks Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
#2173083
10/12/16 07:10 PM
10/12/16 07:10 PM
fast68plymouth
So. Burlington, Vt.
I'm not going to speculate of how much power a set of heads I've never seen or tested would make. Someone will test both versions at some point, then we'll all get a real answer.
And, as with most things motor related......."It depends"(one of my favorite phrases).
But........ When going from std port to MW port..... In general, the bigger the cubes, the higher the cr, the bigger the cam, the better the intake and carb...... The more difference you'll see. A 14:1 572 with an .800 lift roller cam with a TR and dual carbs will see a lot more gain than a 9:1 383 with a performer and a comp he268 cam.
[Re: AndyF]
#2173160
10/12/16 09:35 PM
10/12/16 09:35 PM
tex013
Sydney,Australia
thanks Andy , Dwayne I guess my question was in regard a 493/512 ci motor , where most feel the standard port will hold it back .In a street/strip application under 11.5:1 comp . wait and see how they go . I do like the fact they do not need an offset rocker .
Tex
#2173261
10/12/16 11:32 PM
10/12/16 11:32 PM
fast68plymouth
So. Burlington, Vt.
The only real advantage I see with the TF 270 over a MW EZ head will be fit and finish, and possibly cost. They aren't really breaking any new ground here.
I know the 270 has been eagerly awaited, but frankly I think the 240 made more of an impact on the std port market than the 270 will make on the MW market. But, time will tell.
On a RB 451, the difference in power between ported 300cfm edelbrock heads/ Victor/1050 with a .650 flat tappet cam vs ported 343cfm MW SR's, 440-3/4500 .650 lift roller cam was 60hp......... 652 vs 712.
On that motor, the MW size ports didn't really move the peaks up much in the powerband at all. Maybe 1-200rpm.
#2173265
10/12/16 11:39 PM
10/12/16 11:39 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
^ That said they would still be the best bang for buck MW head out you think ?
We will be buying a set for my sons 440, 11-1 TRW, 650 lift engine, yeah we would be better off with the 240cc but it allows him to look at a stroker package later.
Thanks for all the info in this thread guys !!
1963 Plymouth Max Wedge 1971 Barracuda
#2173268
10/12/16 11:42 PM
10/12/16 11:42 PM
tex013
Sydney,Australia
thanks Dwayne , Andy guess I will see the results later this year
Tex
[Re: SILVER67]
#2173269
10/12/16 11:43 PM
10/12/16 11:43 PM
fast68plymouth
So. Burlington, Vt.
Think the 240 heads are enough alone ?
Do I think if you swapped your mildly ported Edelbrocks for a set of TF 240's, and changed nothing else, that you'd see a gain of 60hp?? No, I don't. But..... There's one way to know for sure.
[Re: SILVER67]
#2173373
10/13/16 03:30 AM
10/13/16 03:30 AM
BradH
Andy, You have an INDY 2D you can test on these heads ? Indy doesn't make a low deck dual-plane intake, only an RB version.
[Re: Cogito]
#2173944
10/13/16 07:34 PM
10/13/16 07:34 PM
BradH
I'm not sure why anyone would want standard port heads on anything larger than a 383 unless they were building a low rpm street car. And this comment is based on what experience, specifically?
[Re: Cogito]
#2173946
10/13/16 07:38 PM
10/13/16 07:38 PM
Posts: 4,704 Wichita
GY3
Wichita
I'm not sure why anyone would want standard port heads on anything larger than a 383 unless they were building a low rpm street car. McFarland's eqn doesn't hold up to reality. Thats exactly what I built. It runs reasonably well for a double duty car, but it is a compromise.
[Re: Cogito]
#2173998
10/13/16 08:36 PM
10/13/16 08:36 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
My 512 C.I. pump gas low deck 906 head(mildy ported with 2.14 int. and 1.81 exh. valves, no magic in those heads) 400 block stroker with a low deck sixpak setup made 612 HP at 5500 RPM and 644 ft lbs at 4500 RPM on CA 91 0ctane pump swill years ago. It ran 10.69 at 124.7 MPH on 91 octane Oregon pump swill at Woodburn through the comnplete 3 inch exhaust and air cleaners on weighing 3450 lbs with me in it. That combination exceeeded my expecations by far There is nothing wrong in using what you have as far as I'm concerned ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I ended up turning that motor into a real street beast by swapping parts around on it, every time I put a better set of heads on it(I put a set of Eddy CNC ported RPM on it after the 906 heads, then a set of Indy M.W. SR with a Indy 400-3 intake and a Holley 1050 CFM Dominator carb and finally a set of Indy CNC ported big valve 440-1 heads that flowed 370 CFM at .700 lift with the same intake and carb. as the SR combination) the car ran faster and quicker, Mopar wedge motors love more air and fuel ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Cogito]
#2174024
10/13/16 09:10 PM
10/13/16 09:10 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I'm not sure why anyone would want standard port heads on anything larger than a 383 unless they were building a low rpm street car. McFarland's eqn doesn't hold up to reality. The formula is a starting point for comparisons, but works better when using a higher velocity like .55 Mach vs .5 Mach. At high altitudes, like here in Colorado, port cross section / velocity seems to affect performance, maybe more than at low altitude?
[Re: BradH]
#2174030
10/13/16 09:17 PM
10/13/16 09:17 PM
Posts: 100 KS
Cogito
KS
I'm not sure why anyone would want standard port heads on anything larger than a 383 unless they were building a low rpm street car. And this comment is based on what experience, specifically? Paying attention.
