08 5.7 PCV valve ? #2169711
10/07/16 04:31 PM
10/07/16 04:31 PM
New Brunswick, Canada
TrxR Offline OP
TrxR  Offline OP
Hey guys what the easiest way to go about changing the PCV valve on a 08 Ram 1500 5.7?
Re: 08 5.7 PCV valve ? [Re: TrxR] #2169719
10/07/16 04:38 PM
10/07/16 04:38 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You can do a "how to" search online and find videos showing how. I have done that for a lot of projects.
Re: 08 5.7 PCV valve ? [Re: TrxR] #2171925
10/11/16 02:04 AM
10/11/16 02:04 AM
md
mopars4ever Offline
mopars4ever  Offline
md
My 06 has a pcv located to the left side of the throttle body. You have to remove the(hemi)filter housing duct that is connected to the throttle body to access it. You have to twist it to remove the pcv.
Re: 08 5.7 PCV valve ? [Re: TrxR] #2172210
10/11/16 03:11 PM
10/11/16 03:11 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
The PCV valve (4) is mounted into the top of the intake manifold (1). This is located to the right / rear of the throttle body (2).
1.
The PCV valve is sealed to the intake manifold with 2 O-rings (2).
2.
Remove PCV valve by rotating counter-clockwise 90 degrees until locating tabs (3) have been freed. After tabs have cleared, pull valve straight up from intake manifold.
3.
After valve is removed, check condition of 2 valve O-rings (2).
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 08 5.7 PCV valve ? [Re: TrxR] #2172213
10/11/16 03:16 PM
10/11/16 03:16 PM
Ringtown, Pa.
Ringtown, Pa.
Pic of pcv valve
Re: 08 5.7 PCV valve ? [Re: stumpy] #2175038
10/15/16 02:44 AM
10/15/16 02:44 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I've done it too. YouTube has all sorts of great videos but there are some idiots there as well.
