72 duster steering column wiring #2171720
10/10/16 10:01 PM
10/10/16 10:01 PM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
Trying to help nepthew with his car, got the ingition switch connector,turn signal switch connector connected to harness,but there is another connector(flat 3 term. violet,tan green wires-comes from turn sinal switch)but i do not see where it goes? or what it may be connected to?
Re: 72 duster steering column wiring [Re: Don_440] #2171875
10/11/16 12:55 AM
10/11/16 12:55 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
My 73 Dart has a third connector for the lights in the gear indicator and for the lighted key that's on a delay. Forget what the 3rd is.
Re: 72 duster steering column wiring [Re: Dave Hall] #2171969
10/11/16 08:33 AM
10/11/16 08:33 AM
Central Illinois
Don_440 Offline OP
Don_440  Offline OP
Central Illinois
Thanks for reply,his column does have the lighted key,but that wire was a single yellow wire with connector,and that was already connected to the time delay
