Is This Ovaled-Out Hole Normal? #2171540
10/10/16 04:30 PM
10/10/16 04:30 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
This is a one-piece kickdown rod from a '79 360/TQ/727. Note the ovaled hole in one side; the other side is still round.
I compared it to 2 other identical 360 pieces and a similar 440 piece I have in my stash and they all look similar. Granted, these are used parts, so did they wear like that or come from the factory this way? shruggy
Re: Is This Ovaled-Out Hole Normal? [Re: vdriver] #2171543
10/10/16 04:31 PM
10/10/16 04:31 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
confused
Re: Is This Ovaled-Out Hole Normal? [Re: vdriver] #2171548
10/10/16 04:46 PM
10/10/16 04:46 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
No. Those should be round. A little weld to fill in, file to shape, and will be good as new. These are wear points and should have a little grease on them.
Re: Is This Ovaled-Out Hole Normal? [Re: vdriver] #2171584
10/10/16 05:34 PM
10/10/16 05:34 PM
Leucadia, Ca.
V
vdriver Offline OP
vdriver  Offline OP
V
Leucadia, Ca.
Thanks, that's what I thought. Just found it weird that all my other spares are the exact same way.
Re: Is This Ovaled-Out Hole Normal? [Re: vdriver] #2171605
10/10/16 06:25 PM
10/10/16 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The slotted hole is perfectly normal, they're all like that. Probably has to do with preventing bind in the one-piece rod.
Re: Is This Ovaled-Out Hole Normal? [Re: vdriver] #2171877
10/11/16 12:59 AM
10/11/16 12:59 AM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I guess I messed mine up then. LOL. It works OK though. After reading what Kunkel said I got to digging around in my parts stash, and sure enough there was the oblong hole. Strangely, only on the later parts, 73 and up. The earlier ones had just round holes that I found.
Re: Is This Ovaled-Out Hole Normal? [Re: John_Kunkel] #2171952
10/11/16 04:13 AM
10/11/16 04:13 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
+1
