Re: Convertible Top Hydraulics - Rebuild or Buy New?
[Re: doubleyellow]
#2172087
10/11/16 12:44 PM
10/11/16 12:44 PM
Posts: 15,575 Omaha Ne
TJP
Omaha Ne
[Re: TJP]
#2173976
10/13/16 08:21 PM
10/13/16 08:21 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Actually I thought I needed to rebuild/replace mine and it turned out all it as is the pump as lo on fluid. I went to the Farm and fleet and bought a 30cc cattle syringe and removed the pump from the mounts (really simple) and added fluid until it leched out the hole.cycled the top up and don a couple times and it works like new. Just a thought before you invest.
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: njmopar]
#2175775
10/16/16 08:00 AM
10/16/16 08:00 AM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Rebuild the pump yourself, not hard, not much too it. Get new lines and cylinders. Use type F trans fluid. I bench bled the system off the car, to ensure all was well before it was in the car an also easier to fill with no mess. If the lines are intact you can easily bleed the air out of the system in the car. All you have to do is run the cylinders up and don until they extend and retract at the same time.
