Why do Oil infomercials always use Mopar Engines? #217149
02/07/09 08:42 PM
02/07/09 08:42 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I remember years ago an Infomercial for Duralube that used a /6 . I just recently ran across this. Once agin a Mopar,but this time a small block.
Is there a scientific reason they use Mopar engines in these torture tests?
http://www.youtube.com/watch?v=fSiS7UYok_Y
Re: Why do Oil infomercials always use Mopar Engines? [Re: SPWC] #217150
02/07/09 09:15 PM
02/07/09 09:15 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
cuz Mopar's are bad [Edited by Moparts - Keep it clean] engines
Re: Why do Oil infomercials always use Mopar Engines? [Re: SPWC] #217151
02/07/09 09:20 PM
02/07/09 09:20 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
Chevies suffer from stage fright.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Why do Oil infomercials always use Mopar Engines? [Re: 78D150CLUB] #217152
02/07/09 10:06 PM
02/07/09 10:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I noticed that also.
That apears to be a 273 swiggin cement
Re: Why do Oil infomercials always use Mopar Engines? [Re: HotRodDave] #217153
02/07/09 10:29 PM
02/07/09 10:29 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Several years ago at a local trade show the Prolong guy had a /6 on the stand, oil pan off, idling away....I stood there & watched, talked to the rep for awhile, eyeballed his HOT girlfriend for a long time, left, came back about an hour later & it was still running.
I made a remark along the lines of "Well, of course it's not gonna seize up...it's a Slant 6!" The dude said "You wouldn't believe how much I hear that.."
Re: Why do Oil infomercials always use Mopar Engines? [Re: SPWC] #217154
02/07/09 10:34 PM
02/07/09 10:34 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
both are solid lifter moto rs and wernt under any load.
Re: Why do Oil infomercials always use Mopar Engines? [Re: moparsquid] #217155
02/08/09 12:00 AM
02/08/09 12:00 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Exactly what I was thinking
Re: Why do Oil infomercials always use Mopar Engines? [Re: HotRodDave] #217156
02/08/09 01:03 PM
02/08/09 01:03 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
+2 When they spray it with the fire hose it actually cools the motor too.
I have seen them supposedly do it with a Viper motor though.
Re: Why do Oil infomercials always use Mopar Engines? [Re: slantzilla] #217157
02/08/09 01:09 PM
02/08/09 01:09 PM
Kirkland, Washington
Pacnorthcuda Offline
We destroyed a slant6 at a show a few years back. Drained the oil, stuck a stick on the throttle (engine was running around 3000 rpm I would estimate). It was a raffle--guess the time and win. Engine seized at about 5 1/2 minutes.
